| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#15 | |
Drives: 18 Brz (Sold) / 22 BRZ
I took to dealership and they said it was not a problem, even though I explained the differences to gen1… Seems like there is too much movement during this condition, not sure if all gen2 cars would have or only some. Probably, removing the lash on the transmission mounts may help (saw some posts having this solution), but it should be Subaru to address that. |
#16 |
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
After reading through this, I've ordered transmission mount support, which would substantially limit lateral movement:
https://www.perrin.com/shop/drivetra...-mount-support ![]() As you can see from the image above it would most help in lateral movements. Here's hoping this helps. I was also wondering if I'd also need to change engine mounts, but this seems to be a good place to start. Thoughts? I'm yet to receive the car myself, so it'll be a while for me to test, but I've seen enough issues in other platforms to know that such misalignment issues might cause bigger troubles in future.. |
| 5th gear gate lockout | UM_BRZ | Issues | Warranty | Recalls / TSB | 5 | 10-21-2020 02:03 PM |
| Gear lockout / grind | Exrald | Issues | Warranty | Recalls / TSB | 2 | 09-05-2018 03:41 AM |
| Installing Raceseng Reverse Lockout and Ashiko/Slammer gear knob. | The Sentinel | DIY (Do-It-Yourself) Guides | 31 | 03-11-2017 07:55 PM |
| Bad Idle, stalling, clutch chatter, gear lockout, failed clutches: My story and fix | Pneub | Engine, Exhaust, Transmission | 11 | 08-05-2016 10:29 AM |
| Gear grinding but... not every days | lludo | Issues | Warranty | Recalls / TSB | 15 | 03-15-2016 05:54 PM |
