Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 03-14-2022, 10:53 AM   #15
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
Originally Posted by dowroa View Post
Since you do have this unique perspective, do you have separated feelings on the My18 vs the MY20 tS, @Veloist?
I believe the Gen1s lifecycle had a more raw initial feel to the final models which appeared to be more refined (sachs dampers, stickier rubber, brembos). It feels like a page from the Porsche playbooks to have return customers to a brand through the lifecycle of a model / generations.
While it has been mentioned that the tS is more cosmetic changes than a rebuild like an WRX --> WRX STi or S209, did you experience the Gen1-base to Gen1 tS? PP models with Sachs + Brembos? While this can be seen as splitting hairs and ineffective changes relative to just STX / SCC prepping a Gen1, I think there is some good discussion to be had in the micro as well, if you have insight here.
To give back some:
I think the simple answer here is to add caster and more "factory" stock camber here. Other S209-like changes with pillowball changes and overall suspension rate changes + good dampers (adaptive / magnetic) could really give more feel back.
And, by the time the tS is ready, maybe tS-specific steering modes / adjustment could be something to give back more feel which you can't just do with bolt-ons.
Thanks for your time and insight, @Veloist.
I did not feel any differences between the ‘18 and ‘20 tS.
However, the differences between the standard BRZ (with & without the Performance Package) and the tS are still apparent (steering feel, turn-in, and confidence from grip). Most of those online/YouTube journalists pretty much say the same thing I did. If you’re familiar with theTopher he even drove a tS against his modified BRZ (13 or 14 I forgot) and consistently got 1 second faster lap times on the track he drove on with the tS.
Veloist is offline   Reply With Quote
The Following 3 Users Say Thank You to Veloist For This Useful Post:
dowroa (03-14-2022), DylanJZA (06-28-2022), Stephen W. (03-15-2022)
Old 03-14-2022, 01:03 PM   #16
dsc_pat
Drives: Too fast
That is obviously a tire difference, because you do not get 1 second from braces, a spoiler and so little spring rate differences. If you get this much from so little, do not get camber bolts, 200tw tires and coilovers...you won't sleep for a week.
I read this topic like the tS is a Honda Type R equivalent, while it is not at all. Most competitive classes do not even account for the tS mods...because they barely have any effect.
dsc_pat is offline   Reply With Quote
The Following User Says Thank You to dsc_pat For This Useful Post:
Robertw (03-15-2022)
Old 03-14-2022, 06:15 PM   #17
Veloist
Veloist's Avatar
Definitely not a type R equivalent, more like the BRZ tS is to the S2000 CR.
This was the mod list of theTopher’s BRZ vs the stock BRZ tS:
2014 Subaru BRZ Mod List (in this video):
225/45/17 Falken Azenis RT-615k Tires
Corsa Performance Catback Exhaust*
2017+ Subaru BRZ Front & Rear Spring/Shock assembly
2017+ Toyota 86 Rear Stabilizer Bar: # SU003-06461
2017+ Toyota 86 Rear Stabilizer Bar Bushings: # SU003-06462
2017+ Subaru BRZ Limited Rear Differential 4.3 Ratio #4111018030
FT86 Speedfactory Catted UEL Header
OpenFlash Tablet FT86 SF Header Tune (Stg 2 91 v3.0)
Corsa Powercore® Closed Box Air Intake PN 185206
17x7.5 SSR GT2 Wheels
Cosworth StreetMaster R90 Fast Road Brake Pads (Front/Rear)
DBA 4000 Front Rotors
StopTech STR-600 Brake Fluid
Whiteline Front Camber Bolts (set to -1º)
Clutch pedal helper spring removed for improved weight/feel
Engine oil: 0w20 Eneos Sustina
Differential fluid: Motul Gear 300
Transmission fluid: Redline MT-90
2018 Subaru BRZ tS:
MSRP: From $33,495
Horsepower: 205 hp
Engine: 2.0 L 4-cylinder
Wheel size: 18″ diameter, 7.5″ width
Curb weight: 2,798 lbs
MPG: 21 city / 29 highway
Torque: 156 lb-ft
Old 06-28-2022, 01:25 AM   #18
rennlistuser3
Drives: 2017 Subaru BRZ
Just wanted to say huge thanks for this post
Absolutely incredible read
rennlistuser3 is offline   Reply With Quote
Old 06-28-2022, 07:15 AM   #19
raisingAnarchy
Drives: '20 Tundra, '84 SpecE30
What a fantastic write up! Every time someone like you posts such beautiful pics of California, it makes me want to put my head in the sand and forget gas prices are a thing and move there!
raisingAnarchy is offline   Reply With Quote
Old 07-03-2022, 08:32 AM   #20
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Great write up. These cars are real close so no point fighting about what’s better, it’s very subjective. I do wonder how much time I could save on my 1 hr highway commute driving mostly straight lines, if I had gotten the TS. Get the TS because it was limited and you like it.
Ernest72 is offline   Reply With Quote
GR86 Premium MPG joeDoe GR86 General Topics (2nd Gen 2022+ Toyota 86) 40 01-31-2022 01:03 PM
GR86/BRZ Comparison Articles Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 74 01-02-2022 08:39 AM
GR86 vs. GT86 track comparison nikitopo GR86 General Topics (2nd Gen 2022+ Toyota 86) 5 12-30-2021 06:48 PM
GR86/BRZ Track Comparison (Japanese) Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 95 12-24-2021 06:36 PM
Car & Driver Comparison Test Review: Veloster N vs. GTI vs. BRZ vs. GR86 LimitedSlip GR86 General Topics (2nd Gen 2022+ Toyota 86) 158 12-12-2021 04:04 PM
