Old 03-09-2022, 12:46 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Pretty much so. For me, AC stuff is NOT a DIY thing. Not much anymore is a DIY thing -
Sure it is! I have a vacuum pump and reclamation stuff. It's all about cleanliness and adherence to process. It's easy to rebuild a compressor. One job and the tools pay for themselves.
Old 03-09-2022, 03:43 PM   #16
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
ran the system check and I got "25". Looking it up now.
Old 03-09-2022, 03:49 PM   #17
Ultramaroon
not playing cards
Solar sensor. I had to replace that on my wife's Camry. Had to take the whole dash off to get to it.
Old 03-09-2022, 04:11 PM   #18
echo419
echo419's Avatar
NVM, it looks like 25 can display if the area is dark. I'm getting 20 and if what I'm reading is right that's supposed to mean no problem....
Old 03-09-2022, 04:15 PM   #19
humfrz
Maybe so. But, all I know, back in the day, it was easier to fix a faulty car AC - just add more ice -
Old 03-09-2022, 04:46 PM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
cheaper than paying my brother a beer and a few slices of pizza? i doubt it.
Old 03-09-2022, 05:16 PM   #21
Ultramaroon
not playing cards
Well... there's that, I guess.
Old 03-09-2022, 05:33 PM   #22
Ultramaroon
not playing cards
The service manifold and gauge kit can be rented but the Harbor Freight version is perfectly ok. Can't beat it for 60 bucks.
https://www.harborfreight.com/automo...set-58776.html
Old 03-11-2022, 04:50 AM   #23
Blackmetal
Drives: 2019 toyota 86 TRD SE 6MT
Hey bro , let me give you a few words of advice .im a ASE MASTER TECH and TOYOTA MASTER TECH for nearly three decades . DTC 25 is stored unless you are in DIRECT sunlight (sun load sensor ) . DTC 20 simply indicates diagnostic check is completed . You won't find a DTC for compressor operation as that HVAC Check is intended to start diagnosis of air distribution ,recirculation, auto functions and blend mechanisms . So try this -
1) gauges are preferred but in a pinch you can put some gloves on and safety glasses ...take off either service cap ....using a golf tee or chopstick or similar item carefully and quickly depress the schraeder valve in the center of service port ....if you get ANY blast of pressure ,this would indicate enough refrigerant to close low pressure switch and your system is "full enough" to allow compressor operation . IF NOT - as in almost no pressure - your system is empty and you need to find the leak source . Look for oily dust around components in AC system including hose crimps and all components ( refrigerant carries oil within the system so when it leaks it's usually fairly easy to inspect visually since you probably don't have an electronic leak detector or black light )
Low system pressure will not allow compressor operation by opening the relay control circuit to ground.
2) using a test light hooked to a solid ground or negative battery terminal , probe compressor mag clutch power feed wire when AC is switched on and blower is operating - if you have 11 volts or above , then the problem is compressor clutch field coil ( which I would suggest complete compressor Assy)
3) if no power on feed wire to mag clutch under same conditions as above - you would move over to the AC mag clutch relay underhood and tap on it , squeeze it ,etc. ( AC SWITCHED ON ) . If it engages , the relay has failed which is fairly common .
4) also at that time , find another relay in the box like horn or cooling fan that is the same style and swap them .if compressor operates go buy a new relay ( make sure you get dealer or at least DENSO)
Get that far and let me know , I'll do the best I can to guide you thru remotely .
Blackmetal is offline   Reply With Quote
Old 03-11-2022, 06:33 AM   #24
Teseo
Drives: frs
I had the same symptoms, o rings lines was replaced.
Old 03-11-2022, 06:59 AM   #25
echo419
echo419's Avatar
@ Blackmetal. Thanks, I'll check it out this weekend. I found that note in the service manual about the 25 code and it did go away when I pulled the car outside.
I'll try and locate #1 and #2 this weekend.
Old 03-14-2022, 12:39 PM   #26
echo419
echo419's Avatar
There's a hole in the actual compressor. But good news is I got a build date of April 24th so I'll have it by April 1st and I won't be worrying about this.
Old 03-14-2022, 02:00 PM   #27
p1l0t
p1l0t's Avatar
Well that's probably the problem right there!
Old 03-14-2022, 03:28 PM   #28
echo419
echo419's Avatar
Someone else's problem in a few weeks.
AC not blowing any cold air highway7 Issues | Warranty | Recalls / TSB 33 12-10-2021 09:58 PM
Aircon blowing cold on one side Kris86 Issues | Warranty | Recalls / TSB 9 05-12-2020 12:36 PM
Sudden lean 17AFR, but then sudden rich 10AFR??? No codes D-VO Software Tuning 4 12-11-2019 12:17 AM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 03:29 PM
Quit old job looking for new one ric342 Southern California 4 08-05-2013 03:36 AM
