| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#16 |
Drives: 2022 GR86 Premium
#17 |
Premium Michelin Pilot 4 noise
I wonder if dynamat everywhere I can put it up front will absorb a mysterious resonant sound I’m just really tuned into or something. I’m really surprised nobody is dealing with this. I guess it’s a good thing. It’s either the Michelins which will get fixed when I put on Contis, or it’s bearings. There nothing else that can do it. Or, it could be typical of the car and I need to get smaller wheels and fatter tires? Maybe dynamat the whole front?
I actually love this car and don’t mind normal road noise from cheap sports cars. It’s the tone that I can hear at all times. |
#18 |
Drives: '22 BRZ Limited 6MT
It’s the tires and the fact that the car has essentially no sound deadening. I too was shocked. There’s a thread in the 2nd gen BRZ subforum.
| The Following User Says Thank You to sds For This Useful Post: | Robotaz (03-06-2022) |
#19 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
1st gen had lots of road noise from tires, not expecting anything different for gen 2. Get a louder exhaust or install a subwoofer and drown out the noise if it really bothers you. Otherwise yea probably not best car for ya.
#20 |
Drives: WR Blue Pearl 2022 Subaru BRZ
Not sure if there are vids of applying sound deadening for the 2nd gen, but its definitely something you will find for first gen.
Both gens in this car are all about making it your own and what you want, so absolutely make it be the car you want and add sound deadening. Down the track you can get some forged wheels or something if you want to claw back the few pounds that you are going to add. Enjoy the modification part of the car! |
| The Following User Says Thank You to Blighty For This Useful Post: | Robotaz (03-06-2022) |
#21 |
I took the car on some amazing roads and drove around an amazing 26,000 acre state park today and the car is awesome. I’m convinced it’s tires and that the most logical solution is to start applying dynamat and see what happens. Because it really resonates in specific areas of the cabin and not others, I’m pretty sure some sound deadening will stop what I’m hearing. I think it’s just resonance in metal surfaces and that dynamat will stop it. It’s not typical tire noise. It really sounds like superposition of random resonances.
I’m going to start applying it in simple areas to access and go from there. If I get results I’ll follow up. |
#22 | |
Drives: 23 BRZ
Why would you keep trying new tires at this point? Either there's another, mechanical issue (i.e. wheel bearing) or the NVH of this car does not suit you. I would rule out mechanical issues before doing anything else suggested (e.g. adding sound deadening or disconnecting the sound generator). You don't want a mechanical sound to turn into a mechanical failure. Can you isolate the noise from the engine? Meaning, if you push in the clutch while at speed (letting the engine drop to idle while the car is still moving) does the sound change? |
#23 |
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
I just posted on another thread about this. My 2019 STI has the exact same rear trunk layout to the new BRZ/GR. If you take the rear trunk trim out you will realize that the noise/frequency you are experiencing is replicated (if not mechanical issue). The sheet metal back there is thin and the vibrates with the exhaust. I laid simple sound deadening and it improved it.
#24 | |
It is resonant noise indirectly caused by tires, and changing tires doesn’t effect it. It’s not mechanical as in moving parts malfunctioning. It’s noise traveling through panels and other metallic objects. Appears to be normal, but annoying. |
#25 |
Drives: '22 BRZ
I would try rotating the tires to see if the sound moves.
You could also take it somewhere and have them put it on a Road Force balancer. That won't be free. You might as well take to the Toyota dealer and see if they will do it for free. It could have a hard spot or something else going on. I had a new, 2014 Ram truck with 20" tires. It would vibrate at ~65 mph. I had the tires Road Force balanced at my work (Kia dealer). Three tires were below 10, one was low 20s. We rotated the tire on the wheel and got it down slightly, but it had a bad/hard spot. I could have probably gone to a Ram dealer and requested them to file a manufacturer claim on the tire. Never got around to it and traded for a BRZ.
2022 BRZ
#26 | |
I’m assuming you just read the first post. Rotating and changing tire types and brands isn’t changing the noise. It’s noise in the body, chassis, and other various metallic components apparently. |
#27 |
TRACKBREAD
If changing tires doesn’t affect it, it’s pretty safe to say it’s not caused by the tires then.
If you want to find out if it’s the fenders having significant mass participation in some specific resonant frequency, you could tape some mass loaded vinyl to the inside of the fender and see if it changes. Easily undone if you use the right adhesive. |
#28 | |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
![]() Just an idea
Math is like Love, simple idea at first that quickly gets complicated
| Michelin Pilot sport as/4 | misterfly | CANADA | 13 | 12-09-2021 03:35 PM |
| Michelin pilot AS3 | nguyen_er | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-04-2015 04:46 PM |
| Michelin Pilot sport A/S 3s ss | jonnyfrank | BRZ First-Gen (2012+) — General Topics | 10 | 09-12-2015 10:57 AM |
| Michelin Pilot Sport A/S 3 87 vs 91 | dontpanic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 39 | 11-16-2014 11:16 PM |
