Old 01-26-2022, 03:31 PM   #15
AsphaltJ
Drives: FR-S '15 Asphalt/Legacy GT '05 Blck
I bought a ST XTA Suspension for 900$ CAN 2 years ago. Bought them without seeing them in person and was shipped via mail. I realize I was lucky it went well.
It's one of the best deal I've ever done. The car now is more confortable and more capable.
Half the price of a new set seems fair to me.
AsphaltJ is offline   Reply With Quote
Old 01-26-2022, 03:34 PM   #16
jflogerzi
jflogerzi's Avatar
To me the Flex A's are a bit overkill his needs but at 1000$ they are a steal IMO
2013 Series 10 FRS #553
Old 01-26-2022, 03:58 PM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
Or buy my used B16s.
The Following User Says Thank You to Pat For This Useful Post:
strat61caster (01-27-2022)
Old 01-26-2022, 06:28 PM   #18
Originally Posted by PatMegron View Post
Sadly i already told the seller I wont be buying from them. Primarily from the concerns here and others as well as being kinda anxious on spending that amount of money right now.
As for intended use, My motivators for buying coils are:
-Possibility of fitting wider wheels in the future
-lowering a tad bit for looks
-increasing comfort level
If it happens to let me zip into corners in a more planted/quicker way when I go on the backroad once every few months then that's a bonus but even at stock I am pretty happy with how the car handles.
I'm looking into the lowering springs but even those I see aren't super ideal supposedly because given the 80k kms my stock suspension has and springs just being there for looks, I might not get as good a value in the long run.
You'll get neither increased comfort nor increased wheel/tire clearance with lowering springs.
Wait and save till you can really get what you want, IMO.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
p1l0t (01-26-2022), PatMegron (01-26-2022), timurrrr (01-28-2022)
Old 01-27-2022, 05:50 PM   #19
jflogerzi
jflogerzi's Avatar
for a street driven car with some camber 17x9 with a decent offset should be fine.
Old 01-27-2022, 06:38 PM   #20
If you don't mind poking wheels and stretched tires, sure it'll fit, but the ride will still be degraded.
Old 01-27-2022, 06:57 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
17X9 +38 with a 245/40 is stretched and poked ?
I had tight fit but most other people seem to not have a problem.
Old 01-27-2022, 07:46 PM   #22
That's not stretched, but it'll also poke without camber, and most tires will be rubbing the spring perch.
Old 01-27-2022, 07:54 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I had no poke on that setup with lowering springs, all else stock. I did have some rub which a lot of people comment they don't have so
Old 01-27-2022, 08:14 PM   #24
Most probably don't realize they're rubbing!
Old 01-28-2022, 12:14 AM   #25
jflogerzi
jflogerzi's Avatar
Camber bolts will be all you need if anything. Yellow spring plus stock dampers are a solid combo. Yes it will be a bit harsher but nothing like cheap coils or really bad lowering springs.
Old 01-28-2022, 12:26 AM   #26
Camber bolts tilt the top of the wheel in, making the rubbing of the tire on the spring perch even worse.
Old 01-28-2022, 09:26 PM   #27
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
And then camber plates will be needed if camber bolts don't work, in which case you're approaching the price range of just getting coilovers...
timurrrr is offline   Reply With Quote
Tein Flex A/ Flex Z Durability jc7993 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-03-2020 09:35 PM
Tein flex a or flex z coilovers? Phuviano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-17-2019 04:37 PM
Tein Flex A vs Flex Z VOSS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-18-2019 05:38 PM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
