Old 01-08-2022, 09:45 AM   #15
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by dvsd1991 View Post
Nope just nice stretch of freeway no curves. I kinda had some access to rod 1 and 4 with the oil pan off didn't notice any play I'll have to give it another look.
I seem remember someone telling me that you can lightly tap the rod caps with a small hammer to determine if there is too much clearance. A loose one will sound different that the others. Might work.
Old 01-08-2022, 12:14 PM   #16
FrickingReallySlow
Drives: 2015 FR-S
Isn’t it 2 and 3 that share the same oil passage on the crank? Have you ever done a used oil analysis prior to this happening? There’s enough space in the upper oil pan for a screw driver to fit it to tap in the rod caps. Did that on mine when I found rtv in my oil filter.
You see the “recall after j02 failure thread” that has similar pics and situations. Your oil pans looks glittery or is that just the light?
FrickingReallySlow is offline   Reply With Quote
Old 01-08-2022, 04:09 PM   #17
dvsd1991
Drives: 2013 white frs
After some tinkering this morning I don't think I wanna invest my time into this project. Any ideas what I should do to maximize my money? How much do you all think I can sell the car for as is? How much do you think a shop would charge to do the repairs? I only bought the car for 8k in 2019.
dvsd1991 is offline   Reply With Quote
The Following User Says Thank You to dvsd1991 For This Useful Post:
TommyW (01-08-2022)
Old 01-08-2022, 04:24 PM   #18
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Well getting it that cheap I’d sell it for about a 4K loss. You’ll spend between 5k and 8k to fix it.
You got is really cheap is there a reason for that? Maybe the previous owner thrashed it?
Old 01-08-2022, 04:52 PM   #19
dvsd1991
It had an accident on record, no structural damage only body. I think mainly it was because it was a 2013 model which people were avoiding. Also it was literally a week before covid shut shut down and dealers were hurting for sales
Old 01-08-2022, 05:09 PM   #20
TommyW
TommyW's Avatar
Well since it was in an accident I’d sell it.
Old 01-14-2022, 01:22 PM   #21
dvsd1991
So I'm trying to price the parts I need to rebuild does anybody know if it would be safe to reuse the AVCS engine cam sprockets? I was reading that in the EJ style motor they can be taken apart and cleaned but not on the FA. I'm concerned that there may be bearing material in there if I rebuild. Also timing chains, tensioners, and guides... ok to reuse? I will replace if necessary, just trying to keep the cost down where possible.
Old 01-14-2022, 01:40 PM   #22
TommyW
TommyW's Avatar
Anything oil touched that can't be cleaned needs to be replaced. Oil coolers especially.
Old 01-14-2022, 03:39 PM   #23
Ultramaroon
not playing cards
Ultramaroon's Avatar
They can be completely disassembled and cleaned. The only slightly challenging part is the internal retaining clip for the control valve (plunger)
Old 01-14-2022, 04:33 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Bet you a beer it is your number 4 rod bearing. It was almost always the number 4 rod bearing.
#3 is the most common. Both 2 and 3 are fed by the same main, 1 and 4 have their own.
Old 01-14-2022, 05:31 PM   #25
In the post recall failures yes. The pre recall failures were predominantly 4 which is the rearmost.
I have always maintained that it was sealant in the oil passages post filter caused by a faulty assembly process. This of course would be slightly different from the blocked pickup tube of the post recall.
More or less a "same but different" scenario.
Old 01-14-2022, 05:35 PM   #26
Did you ever pull it apart enough to find exactly how serious the damage is? Hard to guess on what needs to be changed without knowing how bad it really is.
Old 01-14-2022, 05:57 PM   #27
jflogerzi
jflogerzi's Avatar
Flakes in the oil no Bueno. Its done sadly.
2013 Series 10 FRS #553
Old 01-15-2022, 12:04 AM   #28
dvsd1991
Just pricing for worst case scenario just to get an idea. I will be pulling it apart before ordering new parts.
Tcoat (01-15-2022)
Toyota 86 after crash engine wont start maciekg9 Scion FR-S / Toyota 86 GT86 General Forum 8 11-16-2021 04:53 PM
Spun Rod Bearing? itsAlex Issues | Warranty | Recalls / TSB 38 03-12-2021 09:03 PM
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 06:39 PM
Engine failure - Spun rod bearing TWICE dinoniel Issues | Warranty | Recalls / TSB 38 11-07-2016 01:17 PM
Spun Rod Bearing #4 KE70 Issues | Warranty | Recalls / TSB 13 07-05-2016 03:17 PM
