Old 11-17-2021, 09:31 AM   #15
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Is definitely something something with the transmission. The car absolutely quiet in the morning when I first start it. The sound comes on by the time I get to work, and it goes away every time I press the clutch. I have no idea what would cause it.
With the engine running, go under the hood and put your fingers on the clutch fork. Can you feel vibration that goes with your noise? Try pulling the top of the clutch fork towards the engine and see if it goes away. I rigged a return spring on my clutch fork to get rid of an annoying squeak after installing a Versus fork.
The Following User Says Thank You to blsfrs For This Useful Post:
spcmafia (11-17-2021)
Old 11-17-2021, 01:58 PM   #16
PulsarBeeerz
Drives: JRSC BRZ SOLD
I got that noise after installing the Verus fork as well. I think the harder material is to blame. Doesn't hurt anything but reminds one they aren't oem parts. lol
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
blsfrs (11-17-2021)
Old 11-17-2021, 09:31 PM   #17
blsfrs
blsfrs's Avatar
Did you retain the boot? I trimmed mine to help the thicker fork retract and still had to add a spring.
Old 05-01-2023, 12:06 AM   #18
Slowbro
Drives: '18 BRZ 50th Edition
Back from the dead.. Do you have a picture of your spring you rigged to the Verus fork?
I regret my username..
Slowbro is offline   Reply With Quote
Old 05-02-2023, 12:54 PM   #19
blsfrs
blsfrs's Avatar
Best that could do at this time since my engine is out of the car AGAIN.
I used a heavy zip tie on the clutch fork and made a hook were the bolt for the power brake tube is fastened to the engine. I needed only a little tension to keep the TOB off the PP to get rid of that annoying little squeak.
Understeer Issues - Toe Alignment Issues? NutGud Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-29-2021 08:45 PM
Having issues with my first mod Lantanafrs2 Off-Topic Lounge [WARNING: NO POLITICS] 1 04-22-2020 10:51 PM
VVT Issues bobmcboberston Issues | Warranty | Recalls / TSB 2 06-28-2019 07:17 AM
Lug Nut Issues! srizzors25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 04-07-2015 07:25 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 03:41 PM
