Old 09-24-2021, 10:02 AM   #15
pennafxu
Drives: BRZ. "AKA" Eazy Breezy Blue...
Originally Posted by Dzmitry View Post
As long as you're running aftermarket coilovers, these should work. In terms of your rim size/choice and tire size/choice, it just depends what you're going for. If you're looking for styling, this probably suits your needs, but it will make the car a slow boat and change its dynamics. If you're looking to do some forced induction in the near future, this could be a good way to go.
Thanks...
I guess styling and to clear my BBK... Car is plenty fast with aftermarket exhaust and modified ECU...
Just DD right now. No tracking. I also ordered extended wheel bolts/black lugs and upgraded rear rotors/pads... Will be upgrading lines also to SS.
So will those tires fit?
pennafxu is offline   Reply With Quote
The Following User Says Thank You to pennafxu For This Useful Post:
Dzmitry (09-24-2021)
Old 09-24-2021, 12:36 PM   #16
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by pennafxu View Post
Thanks...
Yep, like I said, as long as you're on aftermarket coilovers, that wheel/tire combo should fit fine. But if you're not, I haven't actually looked into detail of whether your offsets would fit, but with 9.5 and 255 tires, I'm 99% doubtful it would clear stock suspension. I run 18x8.5 ET 38 with 235's all around and they clear the stock struts no problem, but get somewhat close at the front.
Dzmitry is offline   Reply With Quote
Old 09-24-2021, 08:18 PM   #17
pennafxu
Ordered tires... and my stud tool came in...
Dzmitry (09-27-2021)
