#15 |
Drives: 2020 86
No I get it… PTuning has all of my monies, even down to the quarts of Amsoil… Just trying to be save on my daily driver rotors for winter time.
So redirecting this back around. For TRACK rotors, does it make a big difference to do slotted or cryo? |
| The Following User Says Thank You to Jstyle For This Useful Post: | Ultramaroon (09-23-2021) |
#16 |
Slots change pedal fee; cryo no.
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Jstyle (09-23-2021), soundman98 (09-23-2021) |
#17 |
not playing cards
I've always been under the impression that anything more than plain flat rotor was gimmicky at best, and just introduced extra failure point. That's why I've never tried them. Now you have my attention. Do you like them?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | bcj (09-23-2021) |
#18 | |
Drives: Crapcan
#19 |
Drives: 2015 Subaru BRZ Limited DGM
#20 | |
Drilled holes are a failure point. Slots... not so much. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Jstyle (09-25-2021), Ultramaroon (09-23-2021) |
#21 |
not playing cards
Hmmm... so... if I can't go bigger, and I'm getting the pucks hot enough to vaporize... I could get an extra smidge of grab by venting... Is that pretty much the idea?
#22 | |
Drives: 2013 frs base
I'm a bit (or even very) ignorant about brakes. What situation calls for slotted rotors vs blanks? Last edited by blsfrs; 09-24-2021 at 09:54 AM. Reason: wording |
#23 |
At the track
Drives: '14 FRS - Former e92 M3
Many bbk options don't have an option for a blank rotor replacement. Most all of them have only slotted or drilled ring replacement options (see Stoptech as a main example of this).
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
#24 |
Drives: 2013 Subaru BRZ
The RR Racing kit which uses Wilwood calipers and STI rotors does give you that flexibility.
#25 |
Drives: 2020 86
So I just finished my hpde today and the track Marshall actually pulled me aside as I was packing up my stuff and he told me you were the only one I saw today that actually had glowing red rotors and I need to make sure I check brake and fluid when I get home. So does this call for slots or what do you think?
#26 | |
Drives: Crapcan
How bad is this???
Slots won’t help with that. It’s really not an issue, you are just to the point you are putting a lot of energy into the rotors so they get hot and glow. Probably going to be going through consumables a bit quicker if you are getting them that hot. The only thing that will really help that is more mass IE big brake. And even at that it may not go away.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Jstyle (09-25-2021) |
#27 | |
Slots increase bite, not cooling. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | soundman98 (09-25-2021) |
#28 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Jstyle (09-25-2021) |
