Old 08-24-2021, 11:48 PM   #15
jesse2021
Drives: brz
good to hear!
jesse2021 is offline   Reply With Quote
Old 08-25-2021, 07:52 AM   #16
steverife
Drives: 2016 Scion FRS
Wheel studs are junk, car is sensitive to oiling (both temps and type of oil), the '13's can eat coils, pay attention to wheel bearings/hubs.
Honestly, it is all stuff that is pretty standard with any car that you are going to beat on.
With that said, I agree with Code Monkey that you are better served to do your own research.
steverife is offline   Reply With Quote
Old 08-25-2021, 03:22 PM   #17
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
I've got a 2014 with 75k miles and over 150 trackdays (and the same number of autox events). The cars are very reliable at the track. Basic maintenance is all you typically run into (fluids, brake rotors and pads, and wheel bearings).
14stu is offline   Reply With Quote
The Following 2 Users Say Thank You to 14stu For This Useful Post:
JohnJuan (08-30-2021), new2subaru (08-26-2021)
Old 08-26-2021, 03:31 PM   #18
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I have a 2013, over 100 days on track events since 2017, other than consumables the only thing I've replaced is the left CV Axle twice. Still on OEM clutch....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
new2subaru (08-26-2021), ZDan (08-27-2021)
Old 08-27-2021, 10:10 AM   #19
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I mean, consumables can be a pretty broad term. Some people (not me) consider wheels (not just tires), brake calipers, brake lines, and more to be 'consumables' if they're tracking sufficiently.
Of course those same people probably consider engines consumables too...
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
CSG Mike (08-27-2021)
Old 08-27-2021, 11:11 AM   #20
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Yes, to all of the above being consumables and why I opted to stop beating on a 10k motor M3 and got a 3k motor 86... one of the two was/is eventually going to blow up with track use. Just boils down as always to how often you're going to the track if you'll see it in the life of the ownership of your car.
Is it likely to happen, no, but its something to consider and put money aside for. Brakes/tires/fluids are standard though for calculating a good baseline for a yearly track budget
Kelse92 is offline   Reply With Quote
The Following 2 Users Say Thank You to Kelse92 For This Useful Post:
CrowsFeast (08-27-2021), CSG Mike (08-27-2021)
Old 08-27-2021, 12:26 PM   #21
Opie
Opie's Avatar
My consumables have been tires, brake pads & rotors. Plus fluids, filters, plugs etc. as normal maintenance.
Engine, transmission, rear diff, clutch, T/O bearing are all original (as in, they were installed at the factory by Subaru)
The Following User Says Thank You to Opie For This Useful Post:
Old 08-27-2021, 04:39 PM   #22
They're indeed all consumable. It really depends on what you consider acceptable modes of failure, and if the failure may or may not be catastrophic.
I look for a balance between a true racecar interval, and a street car interval, backed by objective data collected (wear rates, temperatures seen, etc.).
Wheels are absolutely consumable if the brakes are getting hot, but if the brakes are getting hot enough to cause this, then the brakes are undersized. If the brakes are getting that hot, then you also cause other failures, such as bending knuckles, knocking wheel bearings out of round, etc.
Conversely, some folks are always needing to replace while others never need wheel bearings. The same folks needing wheel bearings will also tell you things like "i don't need a bbk cuz my brakes don't get that hot", "Don't bother balancing wheels, it's a track/race car", "Does the wheel balance? then run it. Bends don't matter", etc.
Ultimately it comes down to proactive vs reactive maintenace and replacement. For a casual trackday enthusiast, reactive is often the preferred method, because it's cheaper and more convenient. This often transitions to a proactive methodology as track attendance increases, as proactive maintenance is cheaper.
I maintain my car proactively. It's a large contributor to why my car never has any significant downtime, and doesn't suffer catastrophic failure. I don't want to find out what happens if I lose brakes at 140mph. Likewise, it's cheaper for me to sell my wheels lightly used with a low heat cycle count, in near-mint condition, rather than replacing them as they eventually bend from getting soft over use time.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
CrowsFeast (08-31-2021), Opie (08-28-2021), Thefalls (08-30-2021)
Another Salvage BRZ project. 2015 BRZ Track Car Dave-ROR Member's Car Journals 56 10-09-2021 10:32 PM
JRP Track Day - CTMP GP - September 8, 2015 acemanic CANADA 3 09-16-2015 08:21 PM
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
Water pump reliability - track use Kamran Tracking / Autocross / HPDE / Drifting 13 01-20-2013 10:30 AM
