Old 08-12-2021, 07:50 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
To keep your injectors clean. E85 doesn't have cleaning additives. The "cleanness" or "corrosiveness" has nothing to do with keeping the injectors clean.
To everyone else who says they have no issues: Have you ever flowbenched your injectors after just being on ethanol for a long time? Independent data my surprise you and change your mind very, very quickly.
I have heard of this in our cars with pump gas too.
Old 08-12-2021, 08:13 PM   #16
It happens with all fuel, just much faster when you don't have detergents.
Old 08-13-2021, 11:19 AM   #17
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Do tell. Some specifics on those flow tests, length of e85 use, and comparisons to petrol injectors used over a similar time period would be helpful.
So do you think running occasional tanks of petrol will help that? What about occasional off-the-shelf additives? Or is the solution just to change your injectors after a certain period of time (and get advantages of higher flow aftermarket injectors at that time).
CincyJohn is offline   Reply With Quote
Old 08-13-2021, 03:02 PM   #18
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
I’m curious about this too. I want to run E85. But not if it will cause unnecessary harm to my system. So what can I do to ensure this doesn’t happen when running e85.
Or is the best course of action to get a flex fuel kit and upgrade fuel pump and injectors?
Sur is offline   Reply With Quote
Old 08-13-2021, 03:36 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is easier to just go flex fuel. There is only one station in your area I am aware of.
No need to upgrade fuel pump or injectors unless you are FI. I am running all stock fuel system.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Dzmitry (08-16-2021)
Old 08-13-2021, 04:25 PM   #20
Sur
Sur's Avatar
I plan to get a FF kit. But I just wanted to feel the difference in power with E85 now haha
Old 08-16-2021, 09:30 PM   #21
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Haven't seen anyone mention this but if your fuel pump starts to go and you go and do a pull and lean the motor out it could lead to a very large vent being added to your block. Likelihood of that happening is low and I wouldn't worry about it much but I did go ahead and add a fuel pressure safety switch that would yank timing and try to save the motor in the event of fuel pressure loss.
aKaGorganZola is offline   Reply With Quote
Old 08-17-2021, 05:32 AM   #22
steve99
NA car unlikely on any fuel to go bang. also far less likely to be an issue on E85 due its much higher octane rating and knock resistance. Leanout manily issue with boosted cars and fuel pressure safety is good idea
As previous ive run E85 full time for 8 years stock fuel system no issues no additives added to fuel.
ive tuned countless cars to E85 only, our country we have guaranteed 85% ethanol at pump never varies , maybe out E85 better quality.
Many tuners here tune E85 full time no flex many track cars as well , due to the availability of consistent pump E85 that always 85% lots of boosted cars as well.
the only issues ive seen is people adding additives to E85 which i suspect were for petrol and it caused clogged fuel filters with a jelly like substance.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Capt Spaulding (08-17-2021), CincyJohn (08-17-2021)
Old 08-24-2021, 11:27 PM   #23
Maru86
Drives: 2019
@steve99 are you aware of anyone having issues with the HPFP on a diet of E85? I've seen a lot of talk over at NASIOC around HPFP failure on higher ethanol blends for the FA20DIT WRX. Would be keen to hear if you have a theory on why it's been so prevalent for them (fuel quality as you mentioned, additional demands on the pump in the context for the DIT)?
Maru86 is offline   Reply With Quote
Old 08-25-2021, 02:45 AM   #24
steve99
Originally Posted by Maru86 View Post
@steve99 are you aware of anyone having issues with the HPFP on a diet of E85? I've seen a lot of talk over at NASIOC around HPFP failure on higher ethanol blends for the FA20DIT WRX. Would be keen to hear if you have a theory on why it's been so prevalent for them (fuel quality as you menttioned, additional demands on the pump in the context for the DIT)?
Occasionalky hpfp fails on petrol, we have a lot of people on e85 long term here no noticable increase in hpfp or any other tupe of failure on E85 86/brz
I dont know about wrx dit, maybe as a single direct only fuel system it having to run very hard to supply the extra fuel ( maybe the dit tuners are increasing the di pump pressure targets )where as our cars with port and direct systems it not pushed as hard but thars just wild guess.
Old 08-25-2021, 06:30 AM   #25
ermax
ermax's Avatar
e85 "rotation" necessary ...
I’ve got about 3 years on E85 exclusively. The only time I would consider swapping is if you go long periods without out driving the car. For example I wouldn’t put my car away for the winter with E85 in it due to the way it collects water.
FS: TRD "D oval" exhaust, OEM engine mounts, "STi" Radiator Cap cover Dave-ROR Engine, Exhaust, Bolt-Ons 1 05-18-2020 03:34 PM
FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports NvSnickers Wheels and Tires 2 04-04-2017 10:30 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
