Old 08-16-2012, 01:54 PM   #15
solution
solution's Avatar
Drives: Scion FRS
Originally Posted by Stav View Post
Tires are Yokohama S-drive F 225/35/19, R 265/35/19 running -2.5 degree of camber with these. No rubbing if you install properly and align, toe is zeroed out so shouldn't wear to badly.
What Rim Width are you running to for the 225/35/19 tire? 7.5" or 8.5"? I was thinking a 225 on a 8.5" rim would be really stretched.
I went with these rims as well 19"x8.5 and 19"x9.5 - 225/40/19 and 245/35/19 rear. Based on what you said and already running a -2.5" camber I'm thinking im gonna need a little more negative camber because of the larger side wall in the front. What do you think?
Last edited by solution; 08-16-2012 at 02:21 PM. Reason: Edited so the post made more sense.
solution is offline   Reply With Quote
Old 08-17-2012, 07:59 AM   #16
Stav
Stav's Avatar
Drives: 13' FR-S Argento,74' Alfa GTV
Not sure if you missed it but it says right above there. I used 19x8.5 in the front and 19x9.5 in the rear.
Thank you,
Stav is offline   Reply With Quote
Old 08-17-2012, 08:02 AM   #17
Stav
Stav's Avatar
Originally Posted by mrha View Post
How much is the car lowered by?
The car is lowered 2.1 inches front and 2 inches in the rear.
Old 08-17-2012, 08:03 AM   #18
Stav
Stav's Avatar
Originally Posted by TAKUMA View Post
awesome wheels
Thank you, we keep all colors in stock.
Old 08-17-2012, 08:04 AM   #19
Stav
Stav's Avatar
Smile
Originally Posted by colHolm View Post
Looks awesome Steve!
Thanks Chris, now let's get you those 17's
Old 08-17-2012, 09:08 AM   #20
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
tough.
dori. is offline   Reply With Quote
Old 08-17-2012, 09:38 AM   #21
#87
I usually post drunk
#87's Avatar
I am getting OZ over these since they don't offer 17 x 8
#87 is offline   Reply With Quote
Old 08-17-2012, 01:18 PM   #22
Mild2Wild
Drives: Firestorm FR-S
To OP: was that camber measurement all around or just on the front?
Mild2Wild is offline   Reply With Quote
Old 08-17-2012, 01:27 PM   #23
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Look forward to spotting it in the GTA
quik1987 is offline   Reply With Quote
Old 08-18-2012, 09:40 AM   #24
Stav
Stav's Avatar
Thank you,
Missed the question about camber. We dialed in the neg 2.5 as the rear is a little to big for the offset. Rays made the wheel to fit with a 255 not a 265 like I decided to use. I also wanted it fairly low but didn't want to worry about every sipped bump or occasional man hole cover and it's perfect for me.
There are no issues in the front as 225 with a 19 and the correct offset is perfect.
Thank you
Old 04-14-2013, 01:49 PM   #25
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
i notice your front is 19x8.5 +33. Can please confirm the offset ? as Ray website only show +44 or +45
http://www.rayswheels.co.jp/2009/pro...de=GL_57Xtreme
Thanks
Sookainian is offline   Reply With Quote
Old 07-04-2013, 12:02 PM   #26
marioj
Drives: Scion FR-S
Ray's Gramlights
Here is a pic of the rims I got from you on my car. Thanks again for all your help sourcing them. Let me know when you get the centre caps!
Take care,
Mario
marioj is offline   Reply With Quote
Old 07-04-2013, 12:03 PM   #27
loogs
Drives: on cruise control
looks dirty bro
loogs is offline   Reply With Quote
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +45 / 19x9.5 +45 Enjuku Racing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 05-03-2013 02:38 AM
Wheel Directory: Gram Lights 57Ultimate SC Spec 17x8.0 +45 Z86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-30-2013 08:28 AM
Rays Gram Lights 57Xtreme 19 x 9.5rear quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-15-2012 11:50 AM
Wheel Directory: Gram Lights 57Gainer 17x7.0 +42 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-27-2012 01:30 PM
Ray's Gram Light 57Xtreme Wheels - 19x8.5 / 19x9.5 (Set of 4) * IN STOCK * Enjuku Racing Wheels and Tires 1 07-20-2012 08:15 AM
