#15 | |
#16 |
He was getting it at nearly 3/4's full...
2013 Series 10 FRS #553
#17 |
Drives: '23 BRZ
#18 |
Drives: '23 BRZ
I logged data when it was doing it at NHMS and tuner had a look and said "classic fuel starvation". Same exact symptoms at Palmer and at Thompson. Happened sooner at Thompson though, and not associated with any extended/banked left-handers...
#19 |
Famous Potatoes
Drives: '15 ultramarine
Did you replace the black rubber seal(one time use part) and the green ring? And did you put it together properly? I have yet to meet a twin "expert" who has done it correctly.
#20 |
Drives: '23 BRZ
Didn't replace either of those parts. Re-installation went very smoothly, didn't see any evidence of leakage or weirdness when I disassembled again the other day. The green washer ring in particular, don't really see how that would be a problem. IMO it's just there to provide another slip surface so you don't rotate the basket as you tighten the ring. Honestly I think those parts were/are fine, but if/when I go back into it maybe I'll have new replacements on hand.
#21 |
The Stig's German cousin
The one thing I'll point out is that the car will not update the gauge reading unless it detects slightly more than 2 gallons added. Otherwise the gauge just assumes you parked on an incline or the fluid is sloshing around. (Fun fact, if you're on too steep an incline or jack the front end of the car high enough, it will adjust the gauge closer to full!)
The needle's movement towards empty is always a calculated value - e.g. it knows how much fuel is being used and subtracts it from the current gauge reading. So if it doesn't detect a fuel level change big enough to trip it's "this guy just added gas" logic, it'll continue its march towards zero and even give you the fuel light way too early. It's possible that the fuel level reported by OBDII is more accurate but I haven't tested this myself. |
#22 | ||
Drives: '23 BRZ
THANKS! |
#23 | |
Drives: 2016 Scion FRS
With that said, it has gotten "stuck" before. I was going to Michigan a few years ago and maybe an hour into the trip, I noticed the gauge was at a quarter tank. I stopped to top off and the car only took 2-3 gallons of fuel before the pump shut off. Got back in the car and the gauge stayed at a quarter tank. Gauge didn't move until I basically emptied the tank and refilled. |
#24 | ||
Drives: '23 BRZ
Though I still had the fuel starvation (I think) issue at >7/8 tank at a clockwise track that has no extended or banked left-handers... |
#25 |
Drives: 86, 981S, RX8, 2500HD, GenesisV8
Dan I know how to fix it....
Drive slower!!! |
#26 |
Drives: '23 BRZ
nevar!
Haven't done a thing to address the issue. Palmer2 coming up with a long extended lefthander (turns 1-2) that has given fuel starvation (albeit at 1/2 a tank rather than >7/8-tank). Anybody got any suggestions? Current plan is to hope I can consistently get 4 good laps (all I need for the time trial) starting with full tank. But "hope" is often a shite plan! Sometimes works OK tho... |
#27 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#28 | |
Fuel pumps are cheap, and burning one out once a year from starvation is a relatively small price for going faster. It's less than the cost of a single tire. |
| DIY : Draining the gas tank - Methods to empty fuel tank | Mermoz | DIY (Do-It-Yourself) Guides | 13 | 10-09-2025 02:56 PM |
| Fuel Starvation? | Lunatic | Tracking / Autocross / HPDE / Drifting | 37 | 03-28-2018 11:47 PM |
| How to fix fuel starvation on left hand turns - Verus Fuel Door | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 3 | 08-21-2017 03:22 PM |
| Fuel Starvation issues? YAY OR NAY? | track_warrior | Tracking / Autocross / HPDE / Drifting | 23 | 10-22-2013 11:19 AM |
| Fuel Starvation | feldy | Tracking / Autocross / HPDE / Drifting | 1 | 06-09-2012 10:14 AM |
