#15 |
After doing some research, and taking everyone's answers into consideration. I went with an FT86 UEL catted header (should be here today), and will leave the rest alone for the time being. My primary reason for doing this was to eliminate the torque dip and from what I've found the rest of the exhaust has little to no effect.
Going to just have the dealer throw the header on when I take it in for a clutch next month (oem flywheel, exedy stage 1). Then down the road if I feel like messing with the rest of the exhaust I'll just hit it up piece by piece. Appreciate all the replies!
#16 | |
Drives: FR-S '15 Asphalt/Legacy GT '05 Blck
PS. You might consider adding the Verus fork when you change the clutch and be sure to provide the latest version of the throw out bearing (TOB). Last edited by AsphaltJ; 04-15-2021 at 03:51 PM. Reason: Addin info |
| The Following User Says Thank You to AsphaltJ For This Useful Post: | ninjan00dles (04-16-2021) |
#17 | ||
Where I'm at now though it just makes more sense to take it to the dealer and have them do it. I've got the expendable income...so being charged for it doesn't bother me. Quote:
Clutch kit looks to come with a TOB, so should be good on that end. |
#18 | |
Drives: 2015 FRS
I also owned a 91 GS 95 GST 95 GSX and 97 GSX
#19 | |
Definitely fun cars once you get them lined out...until the transmission goes out...because it will...multiple times
#20 |
Additional silly question...Are they going to drain the gear oil out of the tranny before they drop it (replaced it a few years ago with motul)? I'm unfamiliar with these transmissions so idk if it's necessary (used to have to drain dsm trannies cause they'd leak oil out of the front diff). If so, I'll grab some more motul as well.
#21 |
Drives: 2015 FRS
Yeah those cars were a nutcase
No tranny flush, just decouple the driveshaft. DSMs would drain of out of the front axles when you pop them out right? It’s been awhile |
#22 |
lol, yeah there and if awd the transfer case would leak once you slid out the driveshaft. I remember always specifically storing those vertically.
| Perrin Catback Exhaust Group Buy!! Limited Time Offer!! | Mike@CZP | Groupbuys | 1852 | 06-05-2018 05:37 AM |
| Exhaust bolts working off over time? | frosty288 | Engine, Exhaust, Transmission | 4 | 09-28-2015 11:55 AM |
| full exhaust with e85.. Will that damage anything over time? | Anthony7515 | Engine, Exhaust, Transmission | 8 | 04-23-2014 10:00 AM |
| Tax return time = WHEEL CLEARANCE TIME from Gram Lights and Yokohama | vividracing | Wheels and Tires | 4 | 04-04-2014 03:46 PM |
