#15 | |
Sporadic Member
Drives: 2016 Halo FR-S M/T
| The Following User Says Thank You to KR-S For This Useful Post: | strat61caster (04-01-2021) |
#16 |
Drives: 2014 Ultramarine FR-S
Some people (including myself) find the stock pedals a bit far apart to make heel-toe easy.
You can consider getting the SRP wide gas pedal, which I did. Makes it SO much easier to heel-toe and looks OEM. Also much cheaper than the Verus spacer: https://www.srpracing.com/pd-brz-fr-...pedal-only.cfm Highly recommend. Last edited by NLSP; 04-01-2021 at 10:25 PM. |
#17 |
Chin Chief Instructor
Drives: 2015 Ford F150 Aluminium Couch
Was this your first track day ever? Was there an Instructor riding right seat? If not, can you get one? That is going to help you farrrr more than H/T.
2015 Subaru BRZ
2008 NC Miata with 2.5 swap Building 1963 289 Cobra Le Mans Replica Cobra Replica Build Pics Chin Chief Instructor www.ChinTrackDays.com |
| The Following User Says Thank You to jmimac351 For This Useful Post: | femaledog (04-01-2021) |
#18 | |
Drives: 2017 BRZ Perf. Pkg.
2. Probably, I use the cusco pedal. 3. No, learn to do it on your own. 4. Not really once I had the wider pedal. I have small feet. Footwork is something you need to develop. You don't need to be able to heel and toe to turn some quick laps in early groups. Brake, blip, downshift, turn. Eventually those start to overlap each other to the point they seem like one action. In the beginning, be deliberate. Straight line brake. clutch in, rev. downshift. turn. |
#19 |
ProCrastinationConsultant
I've got big clown feet. I toe-toe and keep my heel planted. Find what works for you, there's no perfect solution.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | MICHAEL450f (04-02-2021), SCFD (04-04-2021) |
#20 |
Don't feel bad about the time... SOW is all tire. I am only at a 1:37 there atm. I also can't heel and toe so I use ecutek auto blip plus me trying to blip it to simulate. Focus on line, breaking zones, apex's, etc... Are all other things you need to master. It takes alot of practice to get comfortable at the track. Sounds like you had fun, your car came back in one peice, and you want to go again I would say that was about the perfect first track day.
2013 Series 10 FRS #553
#21 |
Thanks
I liked the cusco pedal.
I found the easiest way to practice was 3-2 down shifts on exit ramps.
| The Following User Says Thank You to ZionsWrath For This Useful Post: | soundman98 (04-03-2021) |
#22 |
Drives: Subaru BRZ
A big part of heel toeing is getting your legs straight so you can rotate your foot. A bent knee will not be conducive to this and will result in you trying to heel toe by using the side of your foot, which is difficult in these cars as the pedals are too far apart.
Straight leg, rotate your foot and use your heel. Practice all the time. It's like wheelies on a bike. You don't need to buy anything to enable you to do it. Just practice. Question on autoblip: a 3-1 shift requires a much bigger blip to match revs than a 4-3. Autoblip doesn't compensate for this does it? Sent from my SM-G973F using Tapatalk Last edited by Purist; 04-03-2021 at 05:27 AM. |
#23 | |
Drives: 18 Brz (Sold) / 22 BRZ
#24 |
after playing more in the car today, i suggest you get used to playing with only rev-matching the car first on the street, and then slowly add heel/toe to the mix after you can competently rev-match alone.
i find this car extremely easy to rev-match (i genuinely believe the factory tune has a 'coaxing mode' that any amount of throttle input engages just the right amount of rpm regardless of actual throttle input amount, and just leaves clutch engagement timing to the user--there's no way i'm as good at it as the car makes it out to be), so i had started heel-toe rev-matching a day after i started trying to rev-match only.
#25 | |
When finding my seat position in any car I rotate my foot like I’m heel toeing and then move the seat back until my knee isn’t on the wheel and gives my hands enough room to turn the wheel. You should also be able to rotate the wheel until your arms are locked without having to lift your shoulder off the seat. |
#26 | |
I felt this car blipped inconsistently until I switched to E85. Before E85 it would randomly give me the middle finger when doing a quick stab. |
| The Following User Says Thank You to ermax For This Useful Post: | soundman98 (04-03-2021) |
#27 |
Drives: '13 Whiteout
One of the better instructional vids
| The Following User Says Thank You to TommyW For This Useful Post: | Capt Spaulding (04-05-2021) |
#28 | |
Turning has never been a problem, but because I do not track the car, this may change if I go to the track. Also, probably I would remove the 2 car seats from the car
| Track day insurance questions | Toyarzee | Tracking / Autocross / HPDE / Drifting | 59 | 04-14-2016 03:24 PM |
| HPDE1 Track Day Questions | Imperius | Tracking / Autocross / HPDE / Drifting | 21 | 04-22-2014 05:46 PM |
| Heel-Toe on track | Howardwei | Tracking / Autocross / HPDE / Drifting | 60 | 08-17-2013 08:31 PM |
| Heel-Toe questions | jwlee7ucla | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 07-31-2013 05:29 PM |
| Some track musings and questions... | circuithero | Tracking / Autocross / HPDE / Drifting | 9 | 01-23-2013 03:50 PM |
