Old 03-23-2021, 03:56 PM   #15
Originally Posted by Nfsundrgrnd View Post
Ok thanks for the input! I love the car and would hate to see it die, which is why I want to learn more about other people's experience with the recall. The car has been running pretty good so I might just hold off on digging into it. If it ain't broke, don't fix it, right?
Remember when you see all those horror stories they total up to a small fraction of a percent of all the cars repaired.
Like everything else people with problems yell it loud and those with no issues remain silent which makes it look like the problem is more prevalent than it is.
ermax (03-24-2021), Nfsundrgrnd (03-24-2021)
Old 03-24-2021, 07:17 AM   #16
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Somewhere there is also a thread for all the people who didn't have issues.
Old 03-24-2021, 11:51 AM   #17
Nfsundrgrnd
Nfsundrgrnd's Avatar
Drives: 2013 WR blue sport tech BRZ
I've been trying to find it but I'm probably blind or something haha.
Nfsundrgrnd is offline   Reply With Quote
Old 03-24-2021, 11:57 AM   #18
DarkSunrise
DarkSunrise's Avatar
I'm at 10,300 miles (1.5 years) after the recall work was done. I do very little commuting with the car, mostly track and canyon. No problems related to the recall.
2022 BRZ Build
2013 FR-S Build
Old 03-24-2021, 12:03 PM   #19
https://www.ft86club.com/forums/showthread.php?t=133383
Old 03-24-2021, 12:06 PM   #20
Nfsundrgrnd
Appreciate the help!
Old 03-24-2021, 01:37 PM   #21
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
I'm in a similar boat as Dadhawk - did mine 2 years ago at about 280k km and I'm at 340 k km now. He hit the nail on the head when it just depends on whether or not it was done correctly.
aghuman is offline   Reply With Quote
The Following 4 Users Say Thank You to aghuman For This Useful Post:
Dadhawk (03-24-2021), ermax (03-24-2021), Hamza (05-14-2021), Tcoat (03-24-2021)
Old 03-24-2021, 09:47 PM   #22
ermax
ermax's Avatar
I wouldn’t bother. Even if it’s a tinny fraction of people that have failures I don’t think it’s worth the risk. When you go to sell it you can tell people it doesn’t have the recall and then they are free to decide if they want to have it done and anyone who does lots of research and sees the threads about failures could potentially value your car higher for not being molested.
This all depends on whether you live in Cali or not.
The Following User Says Thank You to ermax For This Useful Post:
Tcoat (03-30-2021)
Old 03-25-2021, 01:42 PM   #23
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
42,200~ miles the recall work was done.
47,600 miles I put on a turbo kit, new clutch etc. Dropped the oil pan while I was at it and inspected the pickup and screen. No debris, sludge or sealant issues.
Currently at 68,000 miles today.
No issues.
Clueless
YamahaR86 is offline   Reply With Quote
The Following 3 Users Say Thank You to YamahaR86 For This Useful Post:
Dadhawk (03-25-2021), ermax (03-26-2021), Tcoat (03-30-2021)
Old 03-26-2021, 04:44 PM   #24
pasternak
Drives: Asphalt FR-S
68K warranty work done over the summer. Now on CEL 2 since the... 'repair'
pasternak is offline   Reply With Quote
Old 03-30-2021, 04:08 PM   #25
What are the codes though? Could be as simple as a loose hose or not even engine related. Of course it also could be major but that isn't where I would jump off from.
Old 03-30-2021, 04:24 PM   #26
pasternak
P00B.
Old 03-30-2021, 04:43 PM   #27
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
P00B.
For us simps (did I use it properly?)
... engine control module (ECM) has detected a fault with the position and timing of the camshaft. Codes related to the P000B include: P000B: “B” Camshaft Position Slow Response (Bank 1) P0010: "A" Camshaft Position Actuator Circuit (Bank 1)
Several problems may cause a P000B code including:
Possibly loose fuel cap
Low oil pressure causing erratic camshaft position
Restriction to oil flow in oil passages
Restriction to oil flow in variable camshaft timing (VCT) valve body
Damaged or defective VCT phaser
Damaged or defective camshaft position sensor
Damaged or defective camshaft position actuator solenoid
Binding of the camshaft advance mechanism
Damaged or defective ECM (rare)
What are the symptoms of the P000B code?
Symptoms of a P000B code may include:
Check engine or warning light may illuminate
Vehicle rpm may fluctuate during idle
May hesitate when going uphill
There may be no symptoms aside from a stored trouble code
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 03-30-2021, 04:57 PM   #28
pasternak
ie junk in the oil after the warranty recall service I wish I'd never had done.
engine failure, high mileage, recall, valve spring recall
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 08:03 PM
Not doing the Valve Spring Recall? arnie0000 Issues | Warranty | Recalls / TSB 30 08-06-2019 06:24 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
