Old 03-11-2021, 08:12 PM   #15
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Aww, I too didn’t read carefully enough. So these are flywheel estimates so whp will be less, so maybe 45 extra hp going from 8 psi to 11.5 psi according to them with a pulley change and a catback. 305 kW = 410 hp. Assuming a 15-20% drivetrain loss, that is 328-348whp, but probably closer to the lower numbers. That is probably possible on the 85mm pulley on E85 with an aggressive tune, but it is a little high for a conservative tune. I think those numbers would come more from the 75mm pulley. This is a forum member with the 75mm pulley with E85, and I believe he said it was a conservative tune, but I can’t remember, yet he is making 360whp, which a decent amount more than the numbers they gave as an estimate for a 85mm tune, which might be aggressive. The more boost, the more headers and exhausts will make a difference too, as there is more potential for a restriction.
Man, every time I see that plot I have to make a discreet trip to the mens room for some "me time."
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Irace86.2.0 (03-11-2021)
Old 03-12-2021, 01:10 AM   #16
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by 86TOYO2k17 View Post
Dropping compression when not being knock limited will drop power a lot. Especially true with ethanol almost to the point of losing power proportionately to the percent of drop, IE 12.5 to 10 will drop power 20% unless you can make up for that drop with lots of timing/boost (turbo) it’s pointless with a supercharger on ethanol. Perfect example is the few people who went sprintex 335 on E85 with 10:1 compression on small pulley made same power as everyone else on sprintex 210 E85 same pulley. Even though they making way more boost. Or in his case on harrop ethanol 65mm pulley. Maybe arguments for safety margin on track or when ethanol isn’t available. But its a big power sacrifice when sub 20psi on ethanol. Maybe a minor 12:1 or maybe 11.5:1 drop tops.
I agree. I would only drop compression if I was on pump gas or was going for huge numbers. Gains from adding boost are greater than adding compression, so it only makes sense on pump gas or if I was going for 20+ psi, but like you said, that isn't available on these superchargers.
Old 03-12-2021, 04:56 AM   #17
grumpysnapper
grumpysnapper's Avatar
Your low compression build isn't as relevant, but you are still putting down around 435hp at the flywheel or 324kW. What is your compression ratio?
Its the IAG 10.6, primarily because E85 is actually very hard to get here in Australia, so in reality I run on (bad) 98ron for 95% of the time.
Nah, certainly don't call foul on Harrop, because as ever, dyno's, temps, operators, humidity, fuel quality, etc etc etc etc .... always make direct comparison's difficult to interpret.
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
Irace86.2.0 (03-12-2021)
Old 03-12-2021, 05:01 AM   #18
grumpysnapper
E85 is hard to find in Oz, so I'm on 98ron for the vast bulk of the time (and Oz ron ratings are rubbish too).
Old 03-12-2021, 10:49 AM   #19
86TOYO2k17
Drives: 2017 toyota 86
Even a 30% mix does wonders.
I have 6 - 5 gallon justrite safety can type 2
in a 30 gallon eagle flammable cabinet in my garage.
Add 1 - 5 gallon jug to 5.5gallons Pump got me E43 every time. and combined with WMI I had same timing as I would with full E85.
with Bi weekly fill ups. Id make the 1 1/2h round trip once every 3 months.
Not bad for all the benefits of ethanol.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
grumpysnapper (03-12-2021), Irace86.2.0 (03-12-2021)
Old 03-12-2021, 11:02 AM   #20
Irace86.2.0
I do the same with 30 gallons worth of E85, but I have such a short commute that I can do 3 months on full E85. I’ll be starting nursing school in the fall, so I’ll be commuting more, so I’ll consider doing more of a mix. We are suppose to get two stations locally, so I won’t have to drive 25 miles to fill up. What boost level are you at?
Old 03-12-2021, 11:15 AM   #21
86TOYO2k17
I was at 13.5psi according to my boost gauge w/ 69mm on sprintex 210.
I believe injecting wmi pre compressor is chemically changing my VE and adding 1psi of boost as 69mm should be 12.5.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Harrop TVS1320 Supercharger Kit johan Engine, Exhaust, Bolt-Ons 11 04-30-2018 01:05 AM
Fitting HARROP Supercharger wasp47 AUSTRALIA 0 10-19-2017 06:06 PM
WTB Harrop Supercharger Irace86 Want-To-Buy Requests 4 02-15-2017 01:17 PM
Innovate Stage 1 Supercharger with stage 2 accessories azynneo Engine, Exhaust, Bolt-Ons 3 08-30-2016 12:32 AM
Harrop Supercharger fuddbutter AUSTRALIA 32 06-10-2016 01:44 AM
