Old 03-19-2021, 06:44 PM   #15
plucas
plucas's Avatar
Drives: Subaru
Originally Posted by timurrrr View Post
Thanks for the detailed answer!
I agree both can be used, and it makes sense that lasers are easier to switch between cars.
Isn't that a benefit of potentiometeres rather than a downside?
If you know the spring rate (hopefully it's linear), and adjust for the motion ration, you know exactly the weight/force applied at each corner. That value will is not going to be not affected by the compression of the tires. When calculating weight based on dynamic ride height, you have an unknown variable (tire compression) in the equation.
I believe you need some kind of filtering/averaging whatever is it that you measure.
It depends really on what you are looking at and looking for in the data. Just because for what we were doing and using it for doesn't mean others would come to a different conclusion. When trying to compare track data to cfd results, I really want to know the full compression of the system including tires.
Yeah either will certainly require filtering/averaging.
plucas is offline   Reply With Quote
The Following User Says Thank You to plucas For This Useful Post:
timurrrr (03-19-2021)
Old 03-19-2021, 09:45 PM   #16
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Sounds like ideally you'd use both the lasers and suspension pots
This way you can calculate the forces, but also calculate how the body of the car is positioned and angled relative to the pavement.
timurrrr is offline   Reply With Quote
Old 03-21-2021, 09:18 AM   #17
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
If we were doing serious development, looking for every small increase in performance, having both pots and lasers would be extremely helpful for that exact reason.
For our needs, lasers make the most sense and are the slightly more cost-effective way we can implement development across various chassis for aero development.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
timurrrr (03-22-2021)
aero, aerodynamics, subaru brz, track testing, verus engineering
Shave the Front Emblem? Acree Cosmetic Modification (Interior/Exterior/Lighting) 37 01-24-2021 04:26 PM
Will I have to shave my stock studs? whitelightninn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-16-2017 09:56 PM
BRZ antenna shave? Jman1759 Cosmetic Modification (Interior/Exterior/Lighting) 5 08-27-2014 05:05 PM
Antenna Shave ? SmsAlSuwaidi Cosmetic Modification (Interior/Exterior/Lighting) 9 10-09-2013 08:35 PM
How can i shave weight? fernan2 BRZ First-Gen (2012+) — General Topics 15 11-01-2011 11:31 AM
