Old 03-31-2021, 12:31 PM   #15
dodj
Drives: Rallye Blue BRZ
I have never really been that impressed with the speed bleeders.
Ya, they seem to have a 'love'em' or 'hate'em' kind of review history.
dodj is offline   Reply With Quote
Old 04-01-2021, 12:20 AM   #16
N_Raged
Drives: 2019 BRZ Sport-Tech RS
I'm not impressed either. I have the official "Speed Bleeder" brand on my PP Brembos and they require a scary amount of torque to close or else they leak. I'm worried about snapping one off.
Once I find a pressure bleeder that fits I'll be going back to the stock bleeder screws.
N_Raged is offline   Reply With Quote
The Following User Says Thank You to N_Raged For This Useful Post:
NoHaveMSG (04-02-2021)
Old 04-02-2021, 12:35 PM   #17
jflogerzi
jflogerzi's Avatar
Just note if you have access to a large compressor I feel those are the better option but those without these work well.
What is the best way to clean the plastic tank and catch bottle after using them.
2013 Series 10 FRS #553
Old 04-02-2021, 01:44 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You clean it with denatured alcohol.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
jflogerzi (04-06-2021)
Old 04-02-2021, 02:36 PM   #19
JCW 86
JCW 86's Avatar
Drives: 2013 Raven FR-S
Here's another option that keeps your stock bleeders. This is what I've been using.
https://www.turnermotorsport.com/p-1...-simple-bleed/
Comes with a check valve in the bottle so fluid/air is pushed out but not sucked back in. Makes my fluid changes a one man job and have not had any issues.
JCW 86 is offline   Reply With Quote
Old 04-02-2021, 02:44 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Had the same experience with them at work. We tried a set to see if they were feasible to sell to customers as a kit but they made us very uncomfortable with how tight they needed to be. So we became a Motiv distributor and had a custom adaptor made for our application.
Old 04-02-2021, 03:34 PM   #21
N_Raged
Thanks I didn't know about these catch bottles with the check valve! Half the price or less than the Motive pressure bleeder.
The Motive bleeder was on the top of my list but I would find it inconvenient to clean when switching between my wife's DOT3 car and my DOT4 car.
Old 04-15-2021, 01:16 AM   #22
FeRS
bruh
FeRS's Avatar
Drives: Raven 2015 FRS
I've had them on my car for a while and like them. No issues with leaking or anything. I do enjoy the versatility of them over carrying around the larger gravity cans; I just get a bit of tubing and a plastic water bottle when I need to bleed them.
Part is SB1010-SS
<-- why is this an emote
FeRS is offline   Reply With Quote
Old 04-15-2021, 07:32 AM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
Simple bottle with a tube going to the bottom from the cap works fine for me, even without a check valve. In practice just about no fluid gets drawn back as you pump pump pump the fluid through. On the pedal upstroke the master cylinder draws from the reservoir.
Old 04-15-2021, 08:59 AM   #24
Jstyle
Jstyle's Avatar
Drives: 2020 86
Not that it would be hard to change but we can confirm that this will fit right up onto our brakes no prob?
Jstyle is offline   Reply With Quote
Old 05-19-2021, 12:35 AM   #25
jflogerzi
jflogerzi's Avatar
Gotta say even pumping brakes by yourself it's easy to bleed brakes. Just might waste a bit more fluid...
My pressure bleeder broke already ;( will not hold pressure. Just gonna use the motive power bleeder bottles. 2 for 21$ on Amazon
Old 05-19-2021, 12:53 AM   #26
N_Raged
Got this "Allstar Performance" branded one from Amazon but it's the same product. Valve works well. One of my favourite tools I own - cheap, simple, compact, and saves me so much time.
What are some good speed bleeders that you guys recommend? Ryan GT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-09-2019 07:41 PM
WTB: Speed Bleeders KDad2 Want-To-Buy Requests 1 06-16-2018 09:55 AM
DIY - Stainless Steel Lines - Speed Bleeders - Fluid Bleed/Flush F1point4 DIY (Do-It-Yourself) Guides 99 08-24-2017 07:05 PM
GTA Speed Bleeders? FLYFISHR CANADA 0 06-24-2014 12:51 AM
Speed Bleeders - long term reliability amram Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 05-14-2014 08:32 PM
