#15 | |
Drives: 2014 Subaru BRZ
#16 | |
Drives: 86
Jumping in on this relevant thread. I am in the process of trying to eliminate leaks from my exhaust system and am running into many conflicting opinions in terms of the use of gaskets and/or sealants, even within this very thread.
So far I have discovered evidence of a leak between a 2 bolt flange/flat gasket and would like to fix it up the right way. The flanges/join was misaligned (while still bolted tight) when I found it, so I am hoping that is the main reason for the leak. Either way, I wanna do it right when I replace the gasket. The flange surfaces are fairly flat, although not perfect. I have made sure to clean them up nicely. So the question is; a) Gasket only b) Gasket + Spray-A-Gasket Sealant (or other high temp gasket sealant/dressing) c) Gasket + Copper RTV Silicone Gasket Maker d) Copper RTV Silicone Gasket Maker only e) None of the above Many people on various forums seem to recommend/swear by using a gasket + copper RTV gasket maker as your best bet to hold off any leaks. However Permatex themselves specifically state that this is incorrect: Quote:
So, colour me confused... Should I just shut up and take my pick and see how it goes?I have looked at the thicker Remflex gaskets, although they don't seem to be readily available in Oz for a reasonable price. |
#17 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#18 |
Human
Drives: 2015 BRZ Black
The ace headers are known for the bolts backing out, especially the overpipe from the main header.
I've seen alot of people recommend high temp locktite for the bolts. Also make sure after heat cycling a few times after install to tighten everything back down again.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#19 | ||
Drives: 86
Yep, I will be sure to do this after waiting 24 hours for the UC Silicone to fully cure to double check the torque is still good. Last edited by Ads; 02-15-2021 at 01:26 AM. |
| Exhaust Leak | hpanju | Engine, Exhaust, Transmission | 8 | 01-03-2020 11:55 AM |
| Possible exhaust leak? | dar3d3vil | Engine, Exhaust, Transmission | 10 | 02-21-2016 07:45 PM |
| Exhaust leak? | Jman1759 | Engine, Exhaust, Transmission | 4 | 11-29-2014 11:11 PM |
| Exhaust Leak help? | ray7792 | Engine, Exhaust, Transmission | 4 | 07-04-2014 01:08 PM |
| Exhaust leak. | J8boston8j | Engine, Exhaust, Transmission | 17 | 10-15-2013 08:09 PM |
