Old 01-06-2021, 09:40 AM   #15
jflogerzi
jflogerzi's Avatar
Originally Posted by czellers View Post
I have one (Skunk2 powerbox) but i havent installed it yet. its got some kind of aftermarket filter, but i need to snag a K&N or something and see if it makes a difference in the LTFTs first maybe..?
Drop in filter will not cause this in the stock airbox
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
CSG Mike (01-07-2021)
Old 01-06-2021, 09:43 AM   #16
czellers
czellers's Avatar
Drives: 2K19 GT86
Some have suggested an exhaust leak, but I have no clue how that could be a factor... im on a tune specifically for a 100% catless exhaust..
czellers is offline   Reply With Quote
Old 01-06-2021, 09:46 AM   #17
jflogerzi
jflogerzi's Avatar
Mostly if your headers have a leak around the flanges that bolt to the engine block. Everything else would just cause a smell or not ideal exhaust sound.
Old 01-06-2021, 09:48 AM   #18
czellers
czellers's Avatar
Drives: 2K19 GT86
right, but how in the world could that contribute to the fuel trims?
Old 01-06-2021, 09:54 AM   #19
jflogerzi
jflogerzi's Avatar
Remember you have 2 O2 sensors in the header runners so if more air is getting in than what the ecu expects it will adjust fuel trims to try and compensate
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
CSG Mike (01-07-2021), czellers (01-08-2021)
Old 01-06-2021, 10:00 AM   #20
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You can always reset your LTFT's by disconnecting your battery or reflashing your ECU, then see how they set themselves over time. You're not getting any CEL codes accompanying that current LTFT?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-06-2021, 10:00 AM   #21
czellers
czellers's Avatar
Drives: 2K19 GT86
Well, i do think i may have a header issue(s), (installed by previous owner). Im about to snag a tomei expreme UEL...
heres the header thats on there now: https://www.protuninglab.com/20scfrsubrz4.html
Old 01-06-2021, 10:03 AM   #22
jflogerzi
jflogerzi's Avatar
My guess is the gaskets are not seated right or just cheap. Maybe try and order some grimspeed gaskets first before replacing the header.
czellers (01-06-2021)
Old 01-06-2021, 03:16 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The problem with dirt cheap headers is usually the flanges warp. I would try gaskets from remflex. They will seal on really warped surfaces.
https://catalog.remflex.com/
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 01-06-2021, 10:09 PM   #24
Purist
Purist's Avatar
Drives: Subaru BRZ
Hey, I cant help you with your LTFTs, but have a read of the below (if you havent already)
TLDR: OFT tunes are good for between 60 and 90% ethanol. Its easy enough to switch back and forth with an OFT.
I have been running my BRZ on E85 for about 4 years. No issues. But we have garanteed 85% ethanol here.
https://r.tapatalk.com/shareLink/top...ink_source=app
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
Old 01-07-2021, 06:39 AM   #25
ermax
ermax's Avatar
Yeah the OFT tune is super conservative. I’ve been running for years without a flex sensor. The first time I’ve run into an issue was on New Years when I discovered the gas station was closed. I had to go home and swap cars. Only one chain of gas stations has E85 in my city but luckily they are everywhere around me. I still do road trips but only if round trip can be done on one tank (~275 miles). The only con I personally have is that I only make it about 5 days on a tank. Money wise it comes out a tad cheaper than 93. The cold start issues can be resolved with some small tweaks to the boxed OFT tune which only come into play when cranking.
The Following 2 Users Say Thank You to ermax For This Useful Post:
czellers (01-08-2021), PulsarBeeerz (01-10-2021)
Old 01-07-2021, 05:21 PM   #26
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Plumbus View Post
I would never run e85 without a flex fuel kit installed. just the peace of mind is worth every last penny, not to mention you will get the most of the ethanol with a custom tune for it.
I've been flashing between petrol and ethanol tunes on my car for the past 6 years, my car seems okay with it. Though a flex fuel tune is definitely worthwhile. Even at just E19, I can feel (and see in logs) power over premium petrol (E10 91).
Last year I finally put together a kit and am currently testing dialing it in. I'm very glad I did. Also an excuse to play with my engine programming and tables again. Very happy with my result so far. Also my E30 MPG's are not far off from standard CA premium petrol.
Here's going from a tank of E30 to E19 after pumping up 7.5 gallons of shell premium CA piss.
https://datazap.me/u/solidone/e30-e1...zoom=1475-2165
Pretty healthy. lol
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 01-08-2021, 02:19 PM   #27
czellers
czellers's Avatar
Drives: 2K19 GT86
Nope, 0 DTCs/No CEL. Although, the OFT Stage2+ tune 'mutes' most of those due to the exhaust being completely catless...
Old 01-10-2021, 06:16 PM   #28
Turdinator
Señor Member
Turdinator's Avatar
I asked about your intake as the obvious causes of weird trims will be an intake which needs to have the MAF scaled correctly, a leak after your MAF on the intake side or a leak before the oxygen sensor on the exhaust side. The OFT tunes were made on cars with e10 so that is not your cause.
E85 is a great upgrade once you have whatever is causing your high trims sorted. The OFT tune is safe down to e60 I believe. The OFT e85 tunes never received the amount of revisions their petrol ones did so from my experience they aren't quite as refined. As long as you take things a bit easy on the first tank after you flash on or off e85 the OFT setup is fine.
Ecutek with flex fuel and a good tune from a reputable tuner will be more convenient, have better drivability and potentially be more optimised to your header BUT will definitely be more expensive and can't be resold like an OFT can.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
solidONE (01-10-2021)
Anyone here used this Hub conversion? jay1989 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-19-2014 10:33 PM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
E85 conversion ender2664 Engine, Exhaust, Transmission 6 09-15-2013 10:58 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 02:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
