Old 08-01-2024, 03:10 AM   #15
se7en_force
Drives: BRZ 2013
I just encountered this problem on my '13 and made good progress. Same exact problem, pax side low beams turned off after 1 min being on.
Check the fuse. Use the spare in the box if you want to swap it with factory installed one just in case.
Next, my bulb was dead. I got a new one but the BUZZING was still there.
I got new ballasts and now it's quiet as a mouse! So BUZZING means your ballasts are dying.
It still flickers though. Someone up top said the arms were loose so I'll try that next. For now there is no buzzing from the lights, like how I had it when new, the lights are no longer dim either. Just need to figure out the flickering I'm still getting on the pax side. The housing is starting to yellow so if the arms aren't it, I might upgrade the housing to VLANDS.
se7en_force is offline   Reply With Quote
Low Beam Headlight not working 02maher Issues | Warranty | Recalls / TSB 2 07-22-2020 08:17 AM
GT86 Headlight Replica Youngmanhenry Cosmetic Modification (Interior/Exterior/Lighting) 4 02-07-2019 02:39 PM
FS: Brand New GT86 Headlight LHD Beam Pattern nigel-jdmparts Exterior Parts - Lighting 4 08-21-2014 12:48 PM
GT86 Headlight Conversion Noz Cosmetic Modification (Interior/Exterior/Lighting) 12 07-23-2014 12:35 AM
