Old 08-10-2012, 02:03 PM   #15
vtmike
vtmike's Avatar
Drives: Scion FR-S
Originally Posted by onthemove View Post
This, im assuming, is the most easily overlooked thing when it comes to RWD...
Im not super experienced with RWD, just curious if you could elaborate on this?
How about, dont "slam" it into 2nd going around a turn from a dead stop... idk how it is for all cars, but i did it in my aunts camaro ss, all i have to say is good thing the road was wide and no cars were around haha.
Sent from my DROID BIONIC using Tapatalk 2
It's called lift oversteer.
Sent from my Galaxy Nexus using Tapatalk 2
vtmike is offline   Reply With Quote
The Following User Says Thank You to vtmike For This Useful Post:
Guff (08-13-2012)
Old 08-10-2012, 02:13 PM   #16
pr086
Drives: fast
where do you guys typically find your big empty parking lots?
pr086 is offline   Reply With Quote
The Following User Says Thank You to pr086 For This Useful Post:
Quentin (02-03-2015)
Old 08-10-2012, 03:26 PM   #17
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by mechaghost View Post
only place to take off trac and vsc off is during autox and maybe the track! Drive safe!
Note: These comments relate to the Scion FR-S in US configuration. The BRZ and the GT 86 may behave in a slightly different manner.
I drive carefully and well within control on the street, and so having the traction control and VSC off makes very little difference. I rarely reach the limits of the car on the street because these limits are very high for normal street driving. If I feel a little slip (I have quite a bit of experience with RWD cars) I usually take it as a notice to slow down. So far, when I have reached the limits of this car ON THE TRACK, it has been very controllable with no unusual or unexpected reactions from the car (like snap oversteer), so DON'T PANIC if the tires start to slip a little. Also, the car in stock form on a dry road with good traction does not really have enough power and torque to induce a lot of power oversteer, so this is not a primary concern. [Power oversteer is when you apply enough power and torque to the rear wheels to overcome their grip on the road. This causes the rear end of the car to slide out and around the front end of the car.]
If you are CLOSE TO THE CORRECT SPEED going into a corner (only experience will let you understand what this is), the car will PROBABLY make it through close to the correct line if you keep steering in the direction you want to go even if you loose traction a little bit. Keep in mind that I have approached these limits cautiously correctly, and ON THE TRACK due to my experience. If you throw the car into a corner WAY too fast, nothing will save you including traction control or VSC. If you do end up going WAY TOO FAST into a corner and get into a really wicked skid, do not try to keep steering onto the road. Look for a good exit onto the shoulder or other run-off area where you can safely slow down the car (EASE off the throttle in this case), or just put both feet in (on clutch and hard on the brake) and go along for the ride; in this case you will probably spin, but keep traveling in the general direction you car was going when you locked up all 4 wheels. [You need some experience and probably a school (or 3) to teach you how the scenario in the last sentence could play out and why and which option to choose when; it depends on how fast you are going and in what direction, the road conditions, how fast the car is rotating, what lies ahead, and your skill level ]
I have a lot of experience with RWD cars and drive with the traction control and VSC off most of the time. Exceptions to this rule are when it is raining (for now as I have not had time to explore the reactions of these tires in the wet yet). I also leave the traction control on if I am tired or fatigued and do not want to concentrate as much on the car's reactions. I would recommend that newbies leave the traction control and VSC on almost all of the time. Put a good set of WINTER tires on the car in the fall if you live in an area that sees snow or ice during the winter. When driving in snow or icy conditions, you may need to turn off the systems to allow wheel spin to get the car going (especially important with AT), but you can usually turn them back on once you do so.
If you are interested in really learning the limits of your car, do some of the following:
Do take the car to a track that has some good personal instruction. Learn how to approach the limits of the car by slowly and controllably approaching the limits. Ask your instructor to help you learn how to drive without the traction control on once you have mastered the basics.
DO NOT race on the street or see how fast you car can go around a curve on the street. That is what tracks are for; learn how to drive on the track and get involved in some clubs that offer frequent track time and you will soon be bored with anything on the street.
If you are lucky enough to see significant snow (or better yet have access to ice roads on a frozen lake), you can cautiously explore the limits and dynamics of rear wheel drive at very low speeds (shut off the traction control and VSC). Make sure the roads, or parking lot you choose are deserted, or better yet, take a school on the snow at a track or on a frozen lake. Be aware that snowbanks (and especially ditches) can still damage cars, so again cautiously approach the limits.
Old 08-10-2012, 03:29 PM   #18
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
DO take it to driving school.
MmmHamSandwich is offline   Reply With Quote
The Following User Says Thank You to MmmHamSandwich For This Useful Post:
Guff (08-13-2012)
Old 08-10-2012, 03:36 PM   #19
Xenocide117
Xenocide117's Avatar
Drives: 2008 Honda Fit Vivid Blue Pearl
A few weekends of driving my dads 85 corvette toy did wonders for preparing me for the whole new animal of RWD. So easy to suddenly be backwards.
Xenocide117 is offline   Reply With Quote
Old 08-10-2012, 03:41 PM   #20
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
"Don't" use the internet to learn to drive your car.
GenkiElite is offline   Reply With Quote
The Following 5 Users Say Thank You to GenkiElite For This Useful Post:
Guff (08-13-2012), nix (08-11-2012), PERRIN_Chris (08-10-2012), rice_classic (08-13-2012), Tujin (08-13-2012)
Old 08-10-2012, 04:03 PM   #21
Allch Chcar
Drives: N/A
Don't stomp the accelerator, ever. Even at relatively low speeds it can snap oversteer. And it will snap oversteer if you stomp the gas while turning. Always smoothly accelerate/decelerate.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-10-2012, 04:04 PM   #22
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
A lot of racetracks will have a driving school that has a traction control class that use a special car to simulate any condition they want. Such as this
https://www.prodrive.net/programs
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 08-10-2012, 04:11 PM   #23
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Its funny hearing all of this stuff about entering corners and what/whatnot to do. It sounds like RWD is boring for regular driving and more fun for tracking. Because in my RSX I can shift or accelerate in a turn and it stays where I want it but it seems like with RWD its more serious business driving quick around corners.
SUB-FT86 is offline   Reply With Quote
Old 08-10-2012, 04:17 PM   #24
shadoquad
a quote out of context
shadoquad's Avatar
Drives: '20 BRZ, '17 Silverado, '17 S1000R
I've shifted mid-corner in a RWD car. Just have to know what you're doing. And in general, RWD cars are capable of carrying higher speeds through corners than other drivetrains.
RWD is not boring, imo, whether driving regularly or tracking. Just because you're not being excessive or wild in normal driving, that does not imply that it's difficult to enjoy the handling characteristics of a RWD machine at low speeds. They are graceful and fun.
shadoquad is offline   Reply With Quote
The Following User Says Thank You to shadoquad For This Useful Post:
civicdrivr (08-10-2012)
Old 08-10-2012, 04:22 PM   #25
trifenix
Drives: Toyota Tacoma
I think its because rwd>fwd because the effort is split between front tires (braking steering) rear tires (power) Instead of having the front tires do all the work. Enables you to corner more effectively and faster i suppose.
trifenix is offline   Reply With Quote
Old 08-10-2012, 04:29 PM   #26
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
?? I have turned off traction control every single time i have gotten inside one of my cars. I hate it and if you are an experienced driver traction control can actually make you have an accident.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following 2 Users Say Thank You to track_warrior For This Useful Post:
TouchMyHonda (08-10-2012), TuxedoCartman (08-10-2012)
Old 08-10-2012, 04:36 PM   #27
GenkiElite
GenkiElite's Avatar
Is everyone really that new to driving are you guys trying to be funny? It's like this place is full of 15 y/o's with temps.
The Following 2 Users Say Thank You to GenkiElite For This Useful Post:
RyleyMA61 (08-10-2012), Spartan65 (08-13-2012)
Old 08-10-2012, 04:40 PM   #28
TuxedoCartman
Drives: '13 86
Agree. There's a tight U-turn I have to make near my house on a regular basis. With TC off, I can get the car to turn in the space available easily (no, no drama, no fishtailing, no screaming tires... just getting the rear-end to flick around).
The one day I forgot and left the TC on, I nearly curbed my wheel.
TC and stability control are useful when road conditions are bad out... this I will agree with. However, I feel more and more people (and manufacturers, and insurance companies) are treating them as a substitute for good driving skills. Skills that I've spent more than half a lifetime acquiring. I never had stability control on my RX7, WRX, R32 GTR, Mustang Cobra, etc... and never once wrecked those cars, nor even came close to doing so. And that's because I've learned how to drive properly.
TuxedoCartman is offline   Reply With Quote
The Following User Says Thank You to TuxedoCartman For This Useful Post:
