#15 | |
September
Drives: 2015 BRZ
#16 | |
The Dictater
Drives: '13 Red Scion FRS
Alternatively, you could just have bad gas
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | NoHaveMSG (10-19-2020), SamtheKorean (10-19-2020) |
#17 | |
Drives: Crapcan
It going to 1 and holding is a good sign.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | SamtheKorean (10-19-2020) |
#18 |
Take a log and post to datazap. Look for any negative FLKC or Knock Correction (KC) events. Those are the degrees your ECU is pulling from the ignition timing advance to compensate for knock at those specific RPMs and loads.
That said, if your IAM is 1, you probably don't have any serious knock issues.
2022 BRZ Build 2013 FR-S Build |
| The Following 2 Users Say Thank You to DarkSunrise For This Useful Post: | alphasaur (10-22-2020), SamtheKorean (10-19-2020) |
#19 |
September
Drives: 2015 BRZ
Alright so update for anyone helping me out or just browsing, after work today I reflashed my ECU(went back to original oem file and went back to stge 2 + 93oct tune). I noticed my IAM started from value of 0.70 as always did. This time omw to school, IAM did not reach to a whole value of 1.00. It ended up only reaching to 0.87 by the time I was at school. I did a few log recording otw to school, few pulls and normal cruise. I will post a log to see if anything’s wrong.
#20 | |
Drives: Crapcan
#21 | |
September
Drives: 2015 BRZ
#22 |
September
Drives: 2015 BRZ
https://datazap.me/u/samthekorean/lo...1-5-8-12-13-14 heres the log data, is my ltft supposed to stuck in certain value for that amount of time?
#23 | |
The Dictater
Based on your IAM dropping from 1 to .82, it looks like your engine detected a bit of knock but then it got better as it went back up to 1. I wouldn't be too worried on my own car, it happens sometimes. You could try to find better gas. I've found certain stations tend to be better than others for one reason or another. I don't remember if KC learned is supposed to be an absolute value or not, but it is all positive so I'm sure that says... Something? I don't put much stock in KC learned myself. Unless you are into actual competitive racing, it's not going to make much difference in what your car can do given your gas and environment. |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | SamtheKorean (10-20-2020), Ultramaroon (10-20-2020) |
#24 |
Drives: UK GT86
OK here you go:
FLKC is Fine Learnt Knock Correction - Negative is where it is pulling timing, it can only be positive when IAM is less than 1 and is where it is attempting to add timing back in. If successful then the IAM will increase. This is stored in load/RPM regions so if it has added or removed in the past then this will resume from the last stored value. Knock Correction - Usually known as FBKC (Feedback Knock Correction). This is at lower loads, is as it says and is instant feedback. Only FBKC or FLKC can be active at any one time. KC Learn - This is the ignition advance map multiplied by the IAM plus the FLKC value. Or in simple terms, how much ignition advance is being added. Not a useful logged parameter IMO. IAM - If the default value is higher than the IAM at shutdown, then the IAM moves to the default value at startup. The IAM can only increase under certain conditions so it not increasing is not necessarily a sign of an issue. Only if it drops (and TBH if it drops by a reasonable amount) or never reaches 1 would I look at addressing it. If you're happy that you get regular good fuel, I would set it higher than 0.7 and see what happens. Read Here: http://www.romraider.com/forum/topic1840.html
.: Stealth 86 :.
| The Following 3 Users Say Thank You to Kodename47 For This Useful Post: |
#25 | |
September
Drives: 2015 BRZ
| The Following User Says Thank You to SamtheKorean For This Useful Post: | Spuds (10-20-2020) |
#26 |
The Dictater
Lol, well I learned most of what I know through the tuning section of the forum here.
| FR-S engine rebuilt and knocking | DJjoey0812 | Issues | Warranty | Recalls / TSB | 2 | 01-16-2020 07:46 PM |
| Rattle/knocking from engine (video) | draculr | Issues | Warranty | Recalls / TSB | 24 | 08-06-2019 08:57 AM |
| Knocking Raspy Sound from engine bay | 914_WHITE_FRS | Issues | Warranty | Recalls / TSB | 60 | 05-08-2015 01:30 AM |
| loud knocking constant with engine speed | whatsmynameagain | Issues | Warranty | Recalls / TSB | 34 | 12-09-2014 10:58 PM |
| Engine knocking after flash | Tenchi | Software Tuning | 10 | 09-26-2014 12:50 AM |
