#15 |
Master Collaborator
Well, you know the saying:
Old people have problems with new technology (referring to humfrz with his lack of avatar updating skills), and new people have problems with old technology (referring to OP and humfrz for his reply to OP for his ".....back in the day...." solution. My solution? Using a plastic or hard rubber hammer, tap a few times LIGHLTY on top of the plastic fuel pump assembly underneath the access panel of the driver's side rear seat (passenger side on a right-hand drive model) to try and get the float/sender unit unstuck. If that doesn't work, pull the assembly out and test the fuel sender as outlined in the service manual. Replace if necessary. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | humfrz (10-08-2020) |
#16 | |
#17 | |
Master Collaborator
I hear ya'. I try my best to marry the two in order to be as well-balanced as I can. |
#18 |
Drives: 2017 Toyota 86 860 Special Edition
I know this is an older thread, but have you considered the canister vent valve? Our Nissan Versa does the same thing, but keeps clicking unless you fill up really slowly. It seems like its building pressure in a way that the tank thinks its full. Its a new car so its unlikely, but its a thought.
| Tags |
| fuel pump, fuel tank, gas gauge |
| Fuel Gauge Nightmare | JermMX5 | Issues | Warranty | Recalls / TSB | 21 | 07-06-2019 08:50 AM |
| Fuel Gauge is Inaccurate | Surakusa | Issues | Warranty | Recalls / TSB | 13 | 09-02-2017 11:26 PM |
| FS: AEM air/fuel gauge | 264grendel | Miscellaneous | 16 | 02-24-2017 01:06 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 04:39 PM |
| Fuel gauge stuck? | Nate219BRZ | Issues | Warranty | Recalls / TSB | 6 | 08-27-2012 05:40 PM |
