Old 09-14-2020, 09:54 PM   #15
humfrz
Originally Posted by Slade View Post
You're right. I will try it, can I just get some help, when I took out the alternator I removed the belt from the pulley on the alternator, but I am not sure how to remove the belt completely. Also when the belt is removed, if the noise stops does that mean it was a bad belt?
The crank pulley is what is driving the belt. All you have to do is to loosen the belt enough so it doesn't go around, you don't have to take it all the way off.
If the noise stops when the belt is not moving that usually means that something that the belt is driving has a bad bearing and that part needs to be fixed or replaced.
I would start off suspecting the tensioner pully.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
p1l0t (09-15-2020), Slade (09-14-2020), WildCard600 (09-14-2020)
Old 09-14-2020, 09:56 PM   #16
Slade
Slade's Avatar
Drives: 14 Limited BRZ
Doesn’t sound like rod knock.
This is rod knock.
Oh man you're giving me hope. Not gonna lie I'm afraid to get my hopes up.
Slade is offline   Reply With Quote
Old 09-14-2020, 09:58 PM   #17
Slade
Slade's Avatar
Thanks you for this. I will take my car back from the shop its at tomorrow. One more question (Sorry if I am annoying you) should I have the car towed to my house or can I drive it? The shop is literally walking distance from my house so by car its like a 3 minute drive.
The Following User Says Thank You to Slade For This Useful Post:
humfrz (09-14-2020)
Old 09-14-2020, 11:36 PM   #18
humfrz
No, you aren't annoying me -
Well, I'd ask the shop if they would loosen up the belt, just to satisfy your curiosity. If they won't do that, I'd ask them if it would be OK for you to loosen up the belt while it's at their shop.
If not, I'd just drive it home and check it out.
Old 09-15-2020, 01:37 AM   #19
Slade
Slade's Avatar
Originally Posted by solidsnake11 View Post
Was you planning on having the shop replace the engine?
I was at first, They told me they can find me one tomorrow and do the work, but then I decided if I have to get a new engine I might as well go through Subaru and have the dealer do it, even though it will be more expensive. But now it seems like I may not even need a new engine. Praying to Jesus that is the case.
Also I love your username, believe it or not it’s always been a dream to see both of our characters have a crossover one day. Solid Snake vs Slade/Deathstroke. I feel like they are pretty similar. Of course that would never happen
Thanks, I think I’ll just drive it home and loosen it myself. If that doesn’t fix the problem I’d rather go through Subaru to get this replacement done. I also found a DIY on the belt replacement here, it’s pretty much the same thing as when I removed the alternator except you are taking the belt off all the pulleys. I’m sure you knew that obviously but I was happy to see it’s relatively simple.
The Following 2 Users Say Thank You to Slade For This Useful Post:
alphasaur (09-15-2020), humfrz (09-15-2020)
Old 09-15-2020, 02:48 AM   #20
kev0
Drives: '14
Highly suggest not getting a replacement engine, new or used, through the dealership. Just take your time to find one on the internet, even if you have to drive a rental for the meantime. Dealer prices are absolutely bonkers. I'm talking about 13k for a new engine. That's how much a new block costs last time I've seen their pricing list.
kev0 is offline   Reply With Quote
The Following 2 Users Say Thank You to kev0 For This Useful Post:
alphasaur (09-15-2020), Tcoat (09-15-2020)
Old 09-15-2020, 01:30 PM   #21
Slade
Slade's Avatar
Here is the engine running without the belt
humfrz (09-15-2020)
Old 09-15-2020, 02:35 PM   #22
humfrz
OK, so much for the easy fix -
It sounds to me like a valve tappet is really lose, almost like the shim has escaped from underneath the bucket, although I don't know how that would be possible. Maybe something else in the valve train is whacked out. -
Slade (09-16-2020), Tcoat (09-15-2020)
Old 09-15-2020, 02:44 PM   #23
Doesn't sound pretty but I am not convinced that is a whole engine replacement song either. It will of course need to be opened up to see what is what.
I personally would have a hard time jumping to "blown engine" based solely upon that sound.
humfrz (09-15-2020), Slade (09-16-2020)
Old 09-15-2020, 03:03 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Easiest for sure tell without dissembling the engine is have a used oil analysis done. They will be able to pick up the bearing material in the oil if that is what is going on, but that sounds pretty eff'd.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Slade (09-16-2020)
Old 09-15-2020, 03:19 PM   #25
Tokay444
Gotta love the ol’, “my engine sounds like shit/knocks/ticks/etc.” threads, yet they keep starting it and running it, for what I don’t know. Like, maybe it’ll go away if they rev it long enough? Just fix itself?
Old 09-15-2020, 11:12 PM   #26
Tokay444
Wasn’t what I was getting at, at all, but ok.
Old 09-15-2020, 11:55 PM   #27
WildCard600
WildCard600's Avatar
Drives: 2020 86
[David Freiburger] I guess it fixed itself. It is self healing... [/David Freiburger]
WildCard600 is offline   Reply With Quote
The Following User Says Thank You to WildCard600 For This Useful Post:
Tokay444 (09-16-2020)
Old 09-16-2020, 01:02 AM   #28
Slade
Slade's Avatar
Thanks everyone for all the help. I have an appointment this Tuesday at the dealer, they will look at it. I'll fill you guys in.
humfrz (09-16-2020), WildCard600 (09-16-2020)
Idle knocking noise Kostamojen Issues | Warranty | Recalls / TSB 33 04-20-2018 02:09 PM
Engine running rich, stumbling, rough idle after motor swap toyubie Engine, Exhaust, Transmission 19 04-07-2018 01:11 PM
What is this? Knocking Popping Tapping noise from the engine bay no codes arren123 Engine, Exhaust, Transmission 49 01-11-2018 10:18 AM
Knocking on Startup? 636 Issues | Warranty | Recalls / TSB 17 02-03-2014 08:18 AM
Strange engine noise during startup (Video inside) StOpNG0x Issues | Warranty | Recalls / TSB 2 01-29-2013 08:24 AM
