Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
08-31-2020, 09:49 PM | #15 |
Do not know. Haven't seen them myself. Just what the mechanic said. But it definitely felt like there was a lot of slop and movement in the engine when it was trying to start. Makes me think some bearing. Didn't feel like enough to be a completely shattered rod though.
08-31-2020, 09:59 PM | #16 |
Rust bucket enthusiast
The Following User Says Thank You to DarkPira7e For This Useful Post: | Jdmjunkie (08-31-2020) |
08-31-2020, 10:58 PM | #17 |
Drives: '13 Whiteout
08-31-2020, 11:23 PM | #18 |
Drives: Crapcan
Forged pistons expand/contact more with heat then cast. So cold tolerances are looser then with a cast piston. Just google “forged engine piston slap.”
09-01-2020, 10:50 AM | #19 |
The Following 2 Users Say Thank You to TommyW For This Useful Post: | DarkPira7e (09-01-2020), NoHaveMSG (09-01-2020) |
09-01-2020, 10:55 AM | #20 |
Drives: Crapcan
Yes. Sometimes on high HP builds you run a touch more clearance as well because you are subjecting the crown of the piston to more heat, so you need to allow for that expansion too. It is important to get forged pistons up into their operating range before you hammer on them. Especially with engines with aluminum blocks, and even more important if they don't have a liner, and are just a coated bore.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | TommyW (09-01-2020) |
09-01-2020, 08:12 PM | #21 |
So everyone got way off topic. Any ideas as to what would have caused the engine failure? I know we don't have a teardown yet. But it was at cruising speed. 6th gear. Low throttle. Car only has 220hp at the crank.
09-01-2020, 09:52 PM | #22 |
Drives: 2013 FR-S Series 10
Anyone have a crystal ball handy? Or wants to make some intelligent sounding predictions?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
The Following User Says Thank You to Decep For This Useful Post: | NoHaveMSG (09-02-2020) |
09-01-2020, 10:58 PM | #23 |
Drives: Black BRZ
Some of the people in this thread should really visit the JDL turbo and SBD turbo groups on Facebook. There are lots of members in both groups so the sample size is large.
Join the JDL turbo FB group and do a search for "IAG", "built block", etc... ...you will find plenty of discussion on blown blocks from these so called "reputable" brands. Truth be told, at this point the total flaming piece of trash that is the FA20 may be just as much to blame as these engine builders themselves. Not trying to start an argument here but just wanted to point out that there's plenty of misinformation in here. On thing is for sure, this sure as heck isn't an S2K drivetrain - that F20C and the transmission hold 400-450whp all...day...long and then some. Only thing you need to update is the diff...going way off topic here, but anyway... Every time I get the mod bug I can't help but come to the conclusion that the S2K is simply the better platform, especially for taking boost. |
09-02-2020, 12:15 AM | #24 | |
Drives: Crapcan
Building an FA20 is putting lipstick on a pig
09-02-2020, 10:16 AM | #25 |
^^^ That's why I am pretty sure mine is a spun bearing (or two), it will still run but knocks like a bunch of kids beating on a piece of sheet metal with aluminum softball bats. Am I right to assume that there is no simple fix other than rebuild or replace the short block?
09-02-2020, 11:40 AM | #26 |
Drives: Crapcan
Pretty much. The engine needs torn down and the cases split. Labor would be insane on a job like that, and who knows what else you will find.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | gravitylover (09-02-2020) |
09-02-2020, 12:13 PM | #27 |
Drives: FR-S,GTI
I say get original and build a one of a kind. Don't do an LS swap.
Find a Tesla drivetrain from a junkyard and mount it in your BRZ. Get the Dual Motor if you can. The car probably won't handle as well as it used to, but it would be quicker than most anything in a straight line. |
The Following User Says Thank You to WNDSRFR For This Useful Post: | gravitylover (09-02-2020) |
09-12-2020, 05:10 PM | #28 | |
I Love custom Turbo kits
Drives: Limited BRZ
I would tell you to go ahead and swap the engine, but I also tried that, and to be really honest, I liked the car a ton more when it was turbo making 500 WHP than with the LS making 450 WHP and 450 WTQ. I would say but a cheap engine, replace the stock one and enjoy it as is, or just replace it, sell the car and get into a different platform if you are wanting more power.
Tags |
blown engine |
Similar Threads | ||||
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
CEL - Engine Blown!!!!!!! | rapidcars | Issues | Warranty | Recalls / TSB | 65 | 12-10-2014 09:32 PM |
Blown Engine | kombatlion | Forced Induction | 27 | 06-18-2014 06:21 PM |
BRZ Blown engine question | Mujen84 | Forced Induction | 118 | 04-02-2014 05:04 AM |
