Old 08-28-2020, 01:16 PM   #15
ls1ac
ls1ac's Avatar
This is a slippery area.
Top down you drive the car to the track and hope for the best.
Bottom up you take a trailer with everything.
If you are a racer it requires a trailer, and still you will be looking for a friend with something you missed. Next time you will add that. Then you will need a larger trailer. Never ending. I also have an open trailer when i go top down.
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
Hades (10-08-2020), NoHaveMSG (08-28-2020), slowmow (09-01-2020)
Old 08-28-2020, 04:22 PM   #16
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I have surprisingly never lost a coil either, my car being a 13'.
I did only make it 2 laps at an SCCA TT event before losing a motor earlier this year
That's a lap less than I got on my first and only (so far) track day with this car before my engine went too. Extra hurt as I'd bought the car, and got it prepped in time for the next competition because my previous car had gone into the wall (outside rear tire debeaded on turn in).
2019 was a bad track year for me...
CrowsFeast is offline   Reply With Quote
Old 08-28-2020, 05:06 PM   #17
TommyW
TommyW's Avatar
Drives: '13 Whiteout
What went on the motor?
Old 08-28-2020, 06:23 PM   #18
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Spare pads, second set of wheels and tires, fluids.. Frankly, I don't intend to make any significant repair at the track. I get the car inspected every event and we replace anything that looks questionable. I also trailer the car so I can always get home.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
The Following User Says Thank You to Alan For This Useful Post:
Old 08-31-2020, 08:04 AM   #19
CrowsFeast
CrowsFeast's Avatar
Honestly I didn't bother to strip it down and find out for sure. Once the shop got the engine swapped for me I just wanted to go and hide. My track season was over because I just couldn't afford it after that.
Started throwing a smoke screen on the straight but sounded and felt like there wasn't a huge difference (maybe some knock? hard to remember). Limped it back to paddock trying to stay off the racing line. Stopped to talk to one of the marshals when I came off the track and it shut off. IIRC it did start ok at that point and drove back to my parking space. After that if I hit the starter she just basically made terrible sounds.
I've been kinda guessing that it spun a rod. The only thing non-stock about the car engine-wise is the injen intake the PO installed.
Old 08-31-2020, 08:56 AM   #20
Evan55
Drives: 06 Exige, 17 BRZ PP
I forgot a BFH.
Ive smooched the tire wall and pushed in a fender. If you dont have a hammer to keep the fender from rubbing a tire, you're calling a tow truck (or putting it on the trailer)
IMO its best to think of the situations that you want to be able to fix at the track and work backwards.
Evan55 is offline   Reply With Quote
Old 08-31-2020, 09:16 AM   #21
TommyW
TommyW's Avatar
did you have the recall work done prior?
Old 08-31-2020, 11:51 AM   #22
CrowsFeast
CrowsFeast's Avatar
Only had a couple of weeks to get the car ready as I was trying to complete my season in OTA under the same class. Didn't even know about the recall thing yet.
Old 08-31-2020, 01:37 PM   #23
TommyW
TommyW's Avatar
That is a drag for sure. I’m using an IAG short block Stage1 as it has a much better oiling system than stock along with the highly upgraded bearings rods and pistons, etc. also the Killer Bee oil tube which takes care of the issues the stock ones had.
Old 08-31-2020, 01:40 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You got a KB pickup that fit???? Mine was 1/2 inch too long.
Old 09-02-2020, 01:52 AM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by slowmow View Post
Hello all,
I started track driving last year, and I've been slowly assembling a few extra bits (e.g., caliper rebuild kit) to take to the track to solve emergent problems, but I'm wondering what you all have seen break, or alternatively, what you take to the track to make sure you make every session? (Besides the obvious tires, brake pads, oil, brake bleeding stuff, etc.)
Ignition coils? Belt? What say you?
Thanks all!
A backup car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-02-2020, 07:38 AM   #26
slowmow
Drives: 2015 BRZ
slowmow is offline   Reply With Quote
Old 09-02-2020, 07:47 AM   #27
ROADRACER
Drives: unlimited cheap build N/A track car
A torque wrench for your lug nuts. 89 ft/lbs. After 30 plus track days mine have never broken.
Also make sure your oil level is at least at the top mark on the stick to prevent oil starvation during hard cornering.
ROADRACER is offline   Reply With Quote
Old 09-05-2020, 04:46 PM   #28
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
Spare set of wheel/tires, pads, coilpack (2013 woes), motor oil and basic tools. Keeping an eye on oil level is wise. I also keep it near the top mark. Prior preparation is key to finding issues, before they become problems at the track.
No trailer for me. Much simpler to that way.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
The Following User Says Thank You to treedodger For This Useful Post:
slowmow (09-05-2020)
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
Trans balked at 4-5 upshift on track, "Shakey clutch" in paddock ??? Joesurf79 Tracking / Autocross / HPDE / Drifting 1 05-26-2018 04:16 PM
Cantrell Motorsports track event @ "RMP"and some awesome footage with an Air Drone :) glamcem Tracking / Autocross / HPDE / Drifting 23 08-30-2014 07:30 PM
Autocross to Track Day Transition "Dive bombing a tire wall" Rickapl Tracking / Autocross / HPDE / Drifting 13 07-27-2014 10:40 PM
Autocross to Track Day Transition "Dive bombing a tire wall" Rickapl Off-Topic Lounge [WARNING: NO POLITICS] 11 07-15-2014 10:05 PM
