Old 08-17-2020, 12:53 PM   #15
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by TommyW View Post
It isn't bad until it is. On the street if you're very careful it can be ok however in a more track oriented situation Heel toe and rev matching, no.
Though OP was not in a track oriented situation, I do agree otherwise.
Dzmitry is offline   Reply With Quote
Old 08-17-2020, 03:17 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
May i clarify two cases?
- When i try to overtake with max acceleration, i know my current speed, know redline speeds for each gear, know to which i need to switch and blip with throttle for rev match .. what roving though extra gears inbetween will net except extra actions for naught requiring extra time prior starting overtake?
- When i treshold brake on track after long straight and know that 2-3 gears down will be optimal in specific curve or after it .. why should i do those redundant switches? Especially if heal&toeing each of it, imho it will just reduce braking precision by those extra 2-3 gearswitches till right one. So what's wrong with doing just one properly revmatched gearshift straight to one i'll need when i'll need? +on grippy tires on dry tarmac track braking drops speed at high rate taking rather short time/passing specific gear ranges passed rather quickly.
On sequential gearbox i see nothing lost with rowing through gears, switches are quick. But not skipping gears on H-pattern .. i find it counterproductive in some situations.
Way i see, main gain for not skipped sequential downshift nets limits synchro wear for those that don't revmatch, and to have preselected right gear if need to unexpectedly accelerate appears. Such situations almost never happen for me on track (why should i try to accelerate when most of grip is spent on braking and slow speed curve ahead, unless i'm suicidal and want to go off track into wall?) and only some share of downshift cases during daily driving (where admittedly average braking rate is much slower and there actually be often cases of road situation changes to require other inputs then braking) .. so why put such strong emphasize on never ever skipping gears?
Oh, and btw, not-skipping gears will not prevent from misshifting to wrong gear. It didn't for OP and in several other cases i've read or seen videos about, even if if in each of those cases driver actually tried not to skip .. just had put in wrong gear.
Old 08-18-2020, 12:12 PM   #17
chipmunk
Drives: _
(I have tried this on my Yamaha R6, but not on the BRZ yet)
Shifting down thru each gear helps because of engine braking. If you hold the clutch down or shift to neutral, and then slaw on the brakes, the whole kinetic energy is dealt with by the brakes only. However, as you are going down thru mph, being in the right gear for the right mph window, engine braking helps reduce the braking distance.
BUT... having said that, the precision and control it takes to achieve this is very high. Sequential gearing helps a great deal. If one is really trying to shave off 0.1 secs using engine braking, then they probably should invest in a sequential transmission.
chipmunk is offline   Reply With Quote
Old 08-19-2020, 09:44 PM   #18
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
https://www.ft86club.com/forums/showthread.php?t=141959
For related conversation.
FS: Shift Solutions weighted shift knob in Candy Gold - Sold! Ohio Enthusiast Interior Parts (Incl. Lighting) 2 07-22-2020 07:08 PM
Perrin Transmission Mount+Shift Bushing, Whiteline Positive Shift Kit zohaib Transmission and Driveline 5 03-08-2017 11:51 PM
SOLD: Whiteline Positive Shift Kit Bushing, Moddiction Shift Knob immaculate Transmission and Driveline 4 12-30-2016 06:52 PM
SOLD: carbing shift knob infocus shift boot digital camo toby714 Interior Parts (Incl. Lighting) 6 07-02-2015 09:33 PM
FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) wgnzlz Interior Parts (Incl. Lighting) 8 06-09-2014 09:36 PM
