Old 08-02-2020, 11:01 PM   #15
solidsnake11
Drives: brz
I would start by ordering some cheap head gaskets for both fa20 and fa24 then compare them.
solidsnake11 is offline   Reply With Quote
The Following 3 Users Say Thank You to solidsnake11 For This Useful Post:
PulsarBeeerz (08-02-2020), sato (08-17-2021), T-Steve (04-22-2023)
Old 06-01-2023, 11:18 AM   #16
Eaton PSI
Drives: 2013 86
Did anyone ever compare the head gaskets?
The FA20 block doesn't have enough wall thickness to sleeve out to 94mm. Below the water jacketed area around the crank case is quite thin. 90mm pistons is as big as you could safely go.
Eaton PSI is offline   Reply With Quote
Performing FA20 swap with new FA20 Ctoner2653 Engine Swaps 8 09-24-2021 09:40 AM
Blown 2016 FA20 swap 2017 FA20 HRLQN Engine Swaps 11 10-15-2019 08:17 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 04:59 PM
WTB fa20 walletsr Want-To-Buy Requests 0 04-24-2016 11:52 AM
VM vs FA20 CAi speedtrip Engine, Exhaust, Transmission 0 02-05-2013 01:34 PM
