#15 | |
Drives: 17 86
| The Following User Says Thank You to PetrolioBenzina For This Useful Post: | Ultramaroon (08-04-2020) |
#16 |
not playing cards
After my perfectly good factory belt began squeaking over the alternator pulley, I discovered that tiny pieces of gravel had made their way into the grooves of the belt. I spent an hour carefully picking them out. Fixed it right up.
#17 | |
When it was running right, I would amuse myself by catching grasshoppers and putting them on the belt to see if they could jump off before the drive pulley squashed them. - ![]() OK,OK, I was easily amused - times were different - yes, your right it IS my med time. |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#19 |
It was an art to get the belt back on while the tractor was running and not get a finger. They would not let me try until I was 16. A broken rake handle and a quick push. It looked so easy when done right.
| The Following 3 Users Say Thank You to ls1ac For This Useful Post: |
#20 | |
![]() When one part would stop running, things (like the cylinder) would jam up. My father would be busy digging trash out of the parts and my grandfather would try to figure why the belt came off and adjust that pulley. I would sit on the tractor and engage the PTO when they signaled me. Then, like you say, my grandfather would use a hammer handle to "slip" the main drive belt back on. Then, I would run and get the jug of cold well water out from under a pile of lose hay along the fence row, we would all have a big slug - then back to work. |
#21 |
Drives: 2018 BRZ
| The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post: | humfrz (08-05-2020), Ultramaroon (08-05-2020) |
#22 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (08-05-2020), Ultramaroon (08-05-2020) |
| Tags |
| compressor, maintenance, noise, pulley, squeal |
| Odd noise coming from the back | Inteze | Engine, Exhaust, Transmission | 6 | 04-09-2020 02:03 PM |
| Rattling noise coming from car? | YgRoshi | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 04-22-2019 07:32 PM |
| Noise coming from rear of car | B-R-Z | BRZ First-Gen (2012+) — General Topics | 9 | 05-30-2017 07:04 AM |
| Noise coming from the rear end... | jm1681 | Issues | Warranty | Recalls / TSB | 17 | 03-13-2014 08:30 PM |
| Noise coming from the engine. | Zoomryder | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 01-26-2013 11:07 AM |
