#15 |
#1819
Drives: Lightning Red Subaru BRZ
I have 07 STI brembos on my 2013 and the rotors should work otherwise just use the rotor from a 2005 STI.
I've had them on my car since 2013 and have had no problems. |
#16 |
Get a used Sprint AP BBK in the forums and leave stock rears... Proven setup that works...
2013 Series 10 FRS #553
#17 |
Drives: 2014 GT86
jflogerzi: .. except not proven yet for MY2022, which is not just restyle as MY2017 was, but to me looks as different car with radical enough changes. Different car, which may have/need a bit different optimum brake bias. If aftermarket BBKs for predecessor will be as good choice (even if they mechanically fit/bolton just fine) imho will be sure thing only if calipers/disks/pads will be known to be exactly same as on first gens. Otherwise, possibly new, updated versions of BBKs might be needed for MY2022. Or at least testing of it's stock brakes bias is close enough to predecessor's.
#18 | |
#19 |
Drives: Toyota 86 GTS
Sorry for the bump-
Could someone let me know whether this is the DBA rotor previously mentioned in this thread that is used for the 2010+ STI brembos? Having a lot of trouble finding the right one. This one has the 5 holes in the first picture but in the other pictures look like they’re dual drilled https://www.sparesbox.com.au/part/db...4aAlpqEALw_wcB |
#20 |
Drives: 2015 Subaru BRZ Series.Blue #709
^Reported
| Part number for brembo rotors on oem performance package | sroby | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-30-2020 02:03 PM |
| SOLD Brembo ats swap caliper kit with rotors SOLD | Pgh_Area | Brakes, Suspension, Chassis | 2 | 08-08-2017 01:37 PM |
| Brembo STI Fronts w/DBA T3 Rotors | blueap2 | Brakes, Suspension, Chassis | 7 | 06-14-2016 04:36 PM |
| 2013 STi Brembo calipers, pads and rotors | The Racers Line | Brakes, Suspension, Chassis | 9 | 05-29-2015 02:24 PM |
