Old 04-13-2020, 07:58 PM   #15
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Glock_86 View Post
For one I did not just throw parts at the car.
...so i decided to just get a new battery (needed a new one anyhow... ...but still would not start my car. [...] So i went to autozone and got a brand new starter. After installing the new starter, i attempted to start the car again... nothing happened... ...I replaced [the ignition switch] and nothing happened.
I think my assessment is on point.
I think you threw parts at a car that has a bad ground.
Even now, you're tearing into the Main Body ECU... For what reason? Someone on the internet told you? That's a terrible reason, what logical flow led you to that component? What test did you do? What role does that component play in the starting system, and are the symptoms you see, the measurements you take, even compatible with that conclusion?
Old 04-13-2020, 08:02 PM   #16
Glock_86
Glock_86's Avatar
Drives: 2013 Scion FR-S Turbo 14PSI
Alright, well I’ll take your “advice” and look for these bad grounds you speak of... I wouldn’t know what would be a bad ground since the only things that were replaced were the battery and starter... that clearly needed to be replaced because I bench tested both of these items. “Not throwing parts at the vehicle” I understand your trying to make a point.
Glock_86 is offline   Reply With Quote
Old 04-13-2020, 08:12 PM   #17
Glock_86
Glock_86's Avatar
I should just give this car to you so you can professional diagnose the issue. The reason I’m coming on here is to ask question, see if people are willing to help me with finding out the issue, and go from there... not to see a meaningless comment that is harassing me about the way I’m going about diagnosing the issue at hand. You could atleast give some tips but of course what can I expect out of a forum... like come on...
Old 04-13-2020, 08:20 PM   #18
RZNT4R
Look, make it easy. do you have booster cables?
If yes, just put the black clamp on the engine block and the other black clamp directly on the battery negative, that's a simple test anyone can do, and a starter clicking on but not turning the engine over is a very good hint.
Cars typically don't have 5 things go wrong at once unless you drink 5 red bulls and start poking things with a screwdriver. The dash flickering was hint 1, you changed the battery and it stopped flickering, you touched or moved something, but the ground was still resistive, the starter was clicking on but not turning the engine over, that was hint 2, you started changing stuff willy nilly like the ignition switch and poking at the main body ECU which isn't involved in the starting system (according to the OEM wiring diagram in front of me now). 4 things going wrong at once is hint #12825 that you're on the wrong track.
That the dealer tried to throw parts at it is expected, it's a dealer, THEY SUCK SHIT at diagnostic, even more when it's caused by human intervention. You never EVER bring a car in for diagnostics at the dealer unless you know that poor helpless tech has a TSB or recall to steer him right, because without that, they throw parts at problem.
Oh, also, never check a strting system with a voltmeter. It's a high amp circuit, even a bad ground will show 12V on a voltmeter. The GOOD way to check high amp circuits is with a 55W headlight bulb as a test lamp. A bad frame ground on a GMC Savana won't let the fuel pump run, it happens all the time. a voltmeter will show 12V in the pump connector, a regular test light will light up bright as day, but the truck won't run. You have to load a circuit to find out the truth.
Old 04-13-2020, 08:27 PM   #19
soundman98
ProCrastinationConsultant
soundman98's Avatar
ok, i'll play nice.
where's your amp ground located?
Old 04-13-2020, 09:12 PM   #20
Glock_86
Glock_86's Avatar
Okay tomorrow I’m going to look at grounds. May have something to do with my starter negative wire that mounts into my engine.
Old 04-13-2020, 10:12 PM   #21
Lantanafrs2
Drives: 2013 frs red
Relay?
Old 04-13-2020, 10:59 PM   #22
Glock_86
Glock_86's Avatar
Originally Posted by Lantanafrs2 View Post
Relay?
Could be gunna check tomorrow
Old 04-15-2020, 01:37 AM   #23
vladniko86
vladniko86's Avatar
Drives: FRS
I had the same thing on a civic just today, ended up needing to tighten the positive on my starter and the ground cable that goes from battery to body
vladniko86 is offline   Reply With Quote
Old 04-15-2020, 09:07 PM   #24
soundman98
soundman98's Avatar
exactly why i asked where his sub amp ground is..
but he's too busy dodging the questions.
Old 04-15-2020, 10:05 PM   #25
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I think I would be more interested in finding out where he connected his +12V power wire for his amplifier that he installed and how he ran it from the engine bay through the firewall and back to the trunk. This bit of information would tell me a lot.
Maybe he can post some pictures of his electrical connections?
FR-S2GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
soundman98 (04-15-2020), vladniko86 (04-15-2020)
Old 04-15-2020, 10:16 PM   #26
soundman98
soundman98's Avatar
agreed.
but when he posts a massive block of text and starts throwing parts at it, it's best to start simply.
Old 04-16-2020, 02:04 PM   #27
Glock_86
Glock_86's Avatar
yeah you right soundman! block quotes are annoying. And i understand where you guys are coming from.
I fixed my problem. Turns out half the ECU was fried. Replaced it with a new one yesterday and got techstream, so i registered the VIN. Everything works now. Thank you for "some" of your guy's help!
"the symptoms you see, the measurements you take, even compatible with that conclusion?" lol!
The Following User Says Thank You to Glock_86 For This Useful Post:
humfrz (04-16-2020)
Old 04-16-2020, 02:05 PM   #28
vladniko86
vladniko86's Avatar
Drives: FRS
That's wild. How the hell did you fry half of it jeez
#can, #communication, #ecm, #ecu, #immobilizer
OBD2 Communication failure? thecarfilmer Issues | Warranty | Recalls / TSB 7 10-14-2020 04:47 PM
Car won't start, won't crank, no ecu communication redlined600 Issues | Warranty | Recalls / TSB 10 07-09-2016 12:55 PM
Vendor's communication yomny User/Vendor/Sponsor Reviews, Feedback, Comments 19 02-13-2015 11:06 PM
