Old 04-10-2020, 04:45 PM   #15
mrjj
Drives: GT86 2013
I do care about 0-60 times. Please keep posting them, including list of mods!
It doesn't matter that "most dont't care about it", when some do.
mrjj is offline   Reply With Quote
The Following 2 Users Say Thank You to mrjj For This Useful Post:
Contender (04-10-2020), Tanstin (04-12-2020)
Old 04-10-2020, 04:53 PM   #16
Lantanafrs2
Drives: 2013 frs red
Under 6 seconds with e85 and ofh. Car seems to do better when you dust the tire through first gear. Not practical for normal driving of course
Lantanafrs2 is online now   Reply With Quote
Old 04-10-2020, 04:54 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Lantanafrs2 View Post
But the guy was just looking to compare 0-60 times
If he wants to compare data then he needs to provide comparable data. Otherwise it is useless info.
Model Year:
Transmission:
Tire:
Mods:
Launch Control Y/N, Setting:
Timing Method:
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
86TOYO2k17 (04-10-2020), Lantanafrs2 (04-10-2020)
Old 04-10-2020, 05:11 PM   #18
86TOYO2k17
Drives: 2017 toyota 86
Which is generally either for the purpose of having a pissing contest, or to
Compare and validate the benefits of certain modifications.
In either case you need a set standard in which to compare.
I’d much rather compare acceleration numbers over dyno numbers assuming the proper criteria is met. Which most do not.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Old 04-10-2020, 05:27 PM   #19
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'm sure my best was around 6 seconds. You need to spin a bit to avoid the car bogging out and making sure that you spend the most time possible in the higher part of the powerband. When I was able to do a 0-60, I found that conventional launch control hurt my times. Letting the clutch out while the RPM were on the upswing (rather than bouncing in place) meant the inertia from the flywheel let the wheels spin and not bog because of how slow I was actually going. When I got grippy tires, I could not get a good 0-60 no matter what without risking a broken axle, so I stopped caring. When I went turbo, I couldn't use the first 2 gears anyway, so 0-60 was out of the question. 20 to 60 maybe would've been ok.
The Following User Says Thank You to DarkPira7e For This Useful Post:
nikitopo (04-10-2020)
Old 04-10-2020, 08:19 PM   #20
Contender
Drives: 2017 Toyota 86
For the ones who care...Should I post up my previous few runs before OTF tune running all stock ? I only save a few because, they were all about the same.
Now as the car sits..
2017 86
A few TRD badges 5hp x 3 =15 extra hp lol.
6MT
BFG G force comp A2s
Muffler delete
Gutted stock frontpipe
K&N panel filter
Takeda torque booster silicone air tube.
Modified stock air box along with snorkel mod.
Apexl n1 exv coilovers
OTF Stg 1 with idle set at 860rpm and rev limit set to 7,950rpm
Launch set at 2,860rpm
Contender is offline   Reply With Quote
Old 04-10-2020, 08:39 PM   #21
Lantanafrs2
So what was the time?
Old 04-10-2020, 10:56 PM   #22
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Personally, I like acceleration measurements as a complementary to dyno measurements. You can check below (video at 4:30) how some mature tuners are checking their mods. Don't like to start again a BRZ vs. Cayman comparison, but we can learn from the work of others .
However, it doesn't make much sense to measure times from lunch. You are adding many more parameters to have a meaningful comparison and besides you are hurting your clutch! Acceleration measurements from 2nd gear are usually better.
The Following User Says Thank You to nikitopo For This Useful Post:
mrg666 (04-12-2020)
Old 04-11-2020, 11:33 AM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
6.5 from his first post.
I think MT or someone did 6.6 or 6.7 in a stock car. They did repeated runs so could have been warm tires and low fuel. I think the 2850 launch is way too low. I was launching mine at 3800-4k.
Old 04-11-2020, 02:24 PM   #24
Lantanafrs2
Yeah, I had to launch at 4k
Old 04-11-2020, 08:18 PM   #25
Contender
I tried launching at 5,500, 4k, 3,860, 3k all too much wheel spin and hit redline to fast to react in time. 2,860 launch seemed to be my sweet spot.
Old 04-11-2020, 09:35 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Lower your rev limit a bit. And let it hit a few times before taking second. Bet you get a quicker time
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Lantanafrs2 (04-11-2020)
Old 04-12-2020, 12:19 PM   #27
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Ask yourself this is it the time that matters or the feel? I can drive in a twisty road and go maybe 45 mph tops but the feeling as the car goes through the turns is fun.
For straight line you need FI or v8 and lots of low/mid torque to have fun. Driven plenty of muscle cars and they are great until you hit that turn. For me the more I think about it, it’s the low weight of the BRZ that helps it shine. Driven many fast cars with gobs of power but the weight just makes them pigs in the turns. The BRZ is like a go-kart.
Ernest72 is offline   Reply With Quote
Old 04-12-2020, 12:40 PM   #28
mrg666
pessimistic skeptic
mrg666's Avatar
I love that feeling of acceleration at the exit of a curve while trying to control the oversteer, downshifting at the right time, pushing the accelerator just at the edge before breaking traction, like balancing at the edge of a cliff, and then upshifting at peak power to accelerate more after reaching the flat line. Then repeat in the next twist. This is what I love about my car.
Post roll cage lap time differences Walldodger Tracking / Autocross / HPDE / Drifting 7 05-25-2017 02:06 PM
Long time lurker making his first post. JNthe86 Scion FR-S / Toyota 86 GT86 General Forum 24 02-06-2017 12:41 AM
alright my tenth post so i can officaly post in the marketplace destiny86 Scion FR-S / Toyota 86 GT86 General Forum 4 02-04-2016 01:49 PM
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install The Sentinel Engine, Exhaust, Transmission 92 03-09-2015 06:20 PM
post Your 1/4 mile time!!!!! PrDarkKnight Scion FR-S / Toyota 86 GT86 General Forum 35 06-01-2013 10:07 AM
