Old 05-05-2020, 04:08 PM   #15
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
It wouldnt have to be a perfect replica. A rough tall and wide with a lip to go into a cutout. Vertical supports. I could just caulk it into place from behind. If I had the money for a printer, I would be selling them.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 05-05-2020, 04:23 PM   #16
Westen86
Purist
Westen86's Avatar
JUN claims the same part is sold for the R35. It happens to fit the front of an FRS also.
Old 05-05-2020, 04:26 PM   #17
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Keep in mind, where the hole is, that’s where front bumper support beam & foam thingy is. So if you want that to fit, gotta take off the foam & avoid/change the support beam.
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
Spuds (05-08-2020), wparsons (05-08-2020)
Old 05-05-2020, 04:39 PM   #18
Westen86
Purist
Westen86's Avatar
Yea, I was thinking a JDL Bash Bar or one from... Street Faction. I would also use the bar for the splitter rods I need for the 2-piece Verus splitter in my basement.
Old 05-08-2020, 12:18 PM   #19
wparsons
wparsons's Avatar
If you're going to 3D print it and want it to last at all you'll need to print it in ABS, which adds a bit of complexity over PLA (enclosure, hotter temperatures). Most printers are definitely too small to make that in one piece, but if you made it in three pieces you could do it pretty easily.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Spuds (05-08-2020)
Old 05-08-2020, 12:33 PM   #20
RayRay88
Drives: 2017 86 860 Special Edition
I've seen even ABS warp or leech color when left out in the sun, but it's still miles better than PLA.
You might be able to get away with CF filled Nylon in FDM as well, which poses the same challenges as ABS (just on a much larger magnitude).
Ideally you'd want to get the drawings to someone who can print it in SLS GF Nylon or MJF Nylon. SLS Nylon is perfect for duct work like that.
RayRay88 is offline   Reply With Quote
The Following User Says Thank You to RayRay88 For This Useful Post:
wparsons (05-11-2020)
Old 05-08-2020, 01:19 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
ABS is not good with UV . Glycol based fluids will also eat it.
Old 05-08-2020, 01:33 PM   #22
RayRay88
PLA is infinitely worse, if we're splitting hairs.
Old 05-08-2020, 01:40 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I know. I didn't say it wasn't, I won't print anything that is even semi permanent out of PLA. Nylon is going to be the best for most applications, if you can print it. Depending what the part is for I have been going back and forth between PETG and ABS since that is all my printer can handle besides PLA. Most parts that are going to see a lot of sun, I won't bother even trying to 3d print.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 05-14-2020, 12:01 PM   #24
Westen86
Purist
Westen86's Avatar
If its painted inside and out, would that eliminate the UV issue?
Old 05-14-2020, 12:23 PM   #25
RayRay88
Temporarily, but one warm day and some direct sunlight will still cause it to warp and distort.
Old 05-14-2020, 09:31 PM   #26
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
BUMP
https://www.nengun.com/uras/universal-triple-duct
or a knife and a bit of universal edge trim.
https://www.ft86club.com/forums/show....php?p=1959608
The Following User Says Thank You to Kiske For This Useful Post:
Westen86 (05-15-2020)
Old 02-09-2022, 04:14 PM   #27
gpvecchi
gpvecchi's Avatar
I found this camber plate cover for Impreza, that preserves the look of stock struts, may somebody adapt it to the measures of 86?
https://drive.google.com/file/d/1s8_...ew?usp=sharing
gpvecchi is offline   Reply With Quote
custom vinyl graphic printing DarkestBuddha Cosmetic Modification (Interior/Exterior/Lighting) 0 02-06-2016 01:26 AM
3D Printing Ideas? YamahaR86 Cosmetic Modification (Interior/Exterior/Lighting) 11 01-19-2016 07:22 PM
3D printing and beyond Books Member's Car Journals 32 07-01-2015 01:54 AM
Water Transfer Printing mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 9 07-17-2014 01:31 AM
3D printing parts ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 12 07-18-2013 08:44 PM
