Old 03-18-2020, 07:41 PM   #15
ftpwny
Drives: 2013 Subaru BRZ
had similar issues on my 2013 6AT with only 35k miles. cleaning the throttle body fixed it for me. highly recommended
Sent from my Pixel 3 XL using Tapatalk
ftpwny is offline   Reply With Quote
Old 03-20-2020, 01:21 AM   #16
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Totally normal.
mistople is offline   Reply With Quote
Old 03-20-2020, 01:26 AM   #17
DeathToocher
Originally Posted by mistople View Post
Totally normal.
Can you elaborate a bit? Is this a normal occurrence, yet something I should probably fix if I want my engine to last? Or normal as in normal engine operation that will not hurt the engine long term?
DeathToocher is offline   Reply With Quote
Old 03-20-2020, 01:34 AM   #18
mistople
mistople's Avatar
It’s probably just the AC clutch kicking in. I asked the same question to Delicious Tuning way back when I first tuned my car and became hyper aware of every little noise. I don’t think you have anything to worry about.
Old 03-20-2020, 10:45 AM   #19
It is normal. It is not a throttle body, injector, coilpack, or any other mechanical issue but a simple function of the systems.
This is common to many small displacement engines but is a bit more noticeable with these due to the boxer nature.
What you are seeing is the HVAC compressor kicking in and out. If you have the dials set to any windshield setting the system is kicking in no matter if on heat or cold to dry the air blowing against the glass. Next time it is doing it just turn the HVAC right off and it will stop. Turn it back on and it will return.
2013 FR-S Misfire and Rough Idle aemravan Issues | Warranty | Recalls / TSB 98 12-12-2024 01:59 PM
Took my car in for rough idle... Da Brz Issues | Warranty | Recalls / TSB 34 10-29-2016 12:57 AM
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 06:40 PM
Looks like CEL/Rough Idle is getting a lot more attention. wawro569 Scion FR-S / Toyota 86 GT86 General Forum 11 10-06-2012 12:24 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 10:28 PM
