Old 02-29-2020, 02:49 PM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
It's mounted to the under tray and the lip on the bumper cover is blocking a good 1/3 of it. I am getting much higher temps then most people are reporting with a cooler. Going to move it up to the crash bar and build a duct to help funnel more air into it. I don't like it on the under tray anyway as I am afraid an off track will damage it or tear it off.
You can make a bracket attached to the front crash beam like mishimoto. I have mine secured at the top and to the plastic tray. I suppose you can do the same on a aftermarket crash bar, but you'll have some welding to do.
Intent > Content
Old 02-29-2020, 04:04 PM   #16
solidONE
solidONE's Avatar
https://www.harrop.com.au/shop/syste...ngineOilCooler[low].pdf
Wow okay.. That's creative. I think I have enough slack in my lines to lay the oil cooler flat like this. Let me look into this some more. Thanks!
Second thought, mounting the oil cooler facing so close to the ground is a bit dangerous. I remember somebody suggesting this to me when I was bitching about high IAT's after the install. We decided its not worth the risk messing up a lot of people day in an event oil spills on the road. Though I just may cut a hole in one of my front bumpers eventually. Then, it wouldnt matter how hot it got behind the bumper. I'd just have to clean the air filter on a daily basis haha. Something I've been wanting to do since I got the car, but DD. (aka pussed out)
Installing a vent to pull hot radiant air under the car from behind still sound like a good idea with the cooler core mounted vertically or tilted at an angle with some clever ducting.
Intent > Content
Fan\Shroud compatability with JRSC dual oil cooler and radiator Ignore Your Doctor Engine, Exhaust, Transmission 1 11-23-2020 10:38 AM
FS: OEM Fans and Shroud MicheleAbbate Exterior Parts (Aero, Lighting, Etc.) 8 05-14-2020 03:36 PM
FR-S BRZ Low Profile Fan Shroud Carolina Dyno Engine, Exhaust, Bolt-Ons 28 06-16-2015 04:51 PM
FBM Radiator shroud for OEM Rad BRZPDX Forced Induction 2 10-07-2014 01:03 AM
