Old 12-12-2019, 03:00 PM   #15
extrashaky
Drives: 2014 BRZ Limited
Whatever it's like $35 court fee and if you win THEY pay it. (Besides it's more of a bluff tactic just showing up with the form)
He's in Canada though, so the process and warranty requirements may be different there. I think they require a Mountie to present the case before a shaman in a smoke tent or something. Once they come to an agreement everyone shares the royal pudding.
The Following 5 Users Say Thank You to extrashaky For This Useful Post:
Dadhawk (12-12-2019), Dave-ROR (12-13-2019), e30kawi (12-13-2019), finch1750 (12-24-2019), JD001 (12-26-2019)
Old 12-12-2019, 03:19 PM   #16
8inchAzN
Drives: Car
[quote=p1l0t;3282688]
Originally Posted by 8inchAzN View Post
It was a Hub bolt.
Edit:
IT's not worth my time, It was $130 for a bolt + labour. Also in Canada, it's a lot more expensive...and even if you win you still have to go through the hassle of collecting.
An infrequent claimant will pay:
$102 for filing a claim
$89 for filing default judgment
$290 for fixing a date for an assessment hearing
$120 for filing a Notice of Motion for an Assessment in Writing
8inchAzN is offline   Reply With Quote
The Following 2 Users Say Thank You to 8inchAzN For This Useful Post:
e30kawi (12-13-2019), p1l0t (12-12-2019)
Old 12-12-2019, 03:27 PM   #17
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Originally Posted by Grady View Post
The transmission fluid is good for the life of the transmission, just like the factory engine oil is good for the life of the engine.
It's sound logic, although engine oil is somewhat of an open-loop system (lubricates the cylinder walls, also happens to be where the fuel is added/combusts if there's any blow-by). The transmission is a closed-loop system, where the fluid can't burn up or escape without intentionally being removed or a hole blasting through the transmission. Water can get into the engine too if say, you drove underwater. The transmission is still sealed up (you know what I mean lol).
I'll keep researching, but feel free to dazzle me with some science supporting this claim.
ROFL it's Waffle is offline   Reply With Quote
Old 12-12-2019, 03:54 PM   #18
ROFL it's Waffle
My user manual states:
Transfer Case/Transmission - Inspect each transfer case/transmission component for signs of leakage. If you discover any leakage, have it repaired immediately by a qualified technician.
Note: The transfer case/transmission and transmission fluid are a completely sealed unit. Therefore, periodic checks and replacement of the transmission fluid are not required, and there is no dipstick on the transmission. Any repairs that require adding or replacing fluid should be performed by a qualified technician following procedures in Lexus service and repair publications.
Now granted maybe my Lexus is bulletproof, the user manual instructs service intervals up to "180 months or 150,000 miles" and beyond "Inspect transmission for signs of leakage," nowhere does it say "replace transmission oil" except when towing every 60k miles. So maybe, if you're driving it hard... then this is the equivalent of towing... that I can see.
The Following User Says Thank You to ROFL it's Waffle For This Useful Post:
Feistyfrog (12-12-2019)
Old 12-12-2019, 05:16 PM   #19
Grady
Grady's Avatar
No science needed, just logic. It is the same as when I am selling a car and tell them it ran good last time I drove it.
The Following User Says Thank You to Grady For This Useful Post:
Stomachbuzz (12-24-2019)
Old 12-12-2019, 06:40 PM   #20
p1l0t
p1l0t's Avatar
[quote=8inchAzN;3282713]
DAYUM
Old 12-24-2019, 05:52 PM   #21
Stomachbuzz
Drives: 2013 FRS
Originally Posted by yEEt42069 View Post
My BRZ is grinding into 4th gear at high rpms and I'm thinking of taking it into the Subaru dealer to have them take a look at it. Its quite weird because I had my mechanic put in royal purple fluid, and he drained the fluid two times, and never found any metal in the fluid. I've no idea why its grinding, but I just want to know if Subaru will deny warranty claim on the basis of aftermarket fluid? Would it be a good idea to put in the OEM then take it?
How would they ever know if the fluid isn't OEM? It all looks the same after xxxx miles....
You expect them to take a stool sample and send it off to 'the lab'?
Nah, just Bubba in the back who sticks his pinky in and tastes it to determine country of origin and phosphorus content.
Originally Posted by extrashaky View Post
As long as you used the correct weight and type of fluid, they can't really deny warranty coverage. Or rather, they could, but then you'd take them to arbitration and they'd be forced to honor the warranty anyway. They know this, so they're unlikely to try it unless they suspect and think they can prove abuse.
When you say it's "grinding," is it a prolonged grind, or is it a crunch going into gear? If it's a crunch, they're going to tell you that's "normal" for transmissions in Subarus.
BTW, when I asked my dealership about 3 and 5 crunching in mine, the tech actually suggested I try Motul instead of the stock stuff. So like I said, they don't really care what brand you put in it as long as it's the correct weight and type of lubricant.
PLEASE do not mistake one employee, with zero administrative power, for the "attitude/policy of the corporation".
The McDonald's cashier saying "yeah I'm pretty sure there's no peanuts in that..." is not the same as the official policy of McDonalds, published by the CEO and Board of Directors.
People make mistakes and say wrong stuff all the time. It's human nature. I've done it. Just please be more cautious.
Perhaps I need to go check out the transmission threads, but isn't the OEM fluid good for the life of the car? Just because they put a fill and drain port on the transmission (to me) doesn't mean it should be changed regularly/ever. Flushing a transmission sounds like trouble waiting to happen (clogging check-valves with metal bits that wouldn't normally make their way to check-valves without being flushed into that location). I know dealers try to scare customers into doing this unnecessary change, but I haven't seen this in any owners manuals or recommended by the manufacturer.
First of all, nobody said anything about a 'flush'.
Second, I'm not sure where you got some of this info from, but a lot of it sounds like made-up monkey nonsense with zero scientific or factual backing.
"Clogging check-valves with metal bits". Bruh, if you got metal 'bits' large enough to clog check valves, you got much bigger issues.
Third, between the "it's lifetime fluid, guys!" and the "the owner's manual doesn't say anything about a transmission flush!" I think you take the owner's manual a little too literally.
Lifetime fluid is pretty much a ruse. Not so much in that it's fake, but more like people don't understand what "lifetime" means.
It reminds me of a time someone came on a Tacoma forum who was upset that his tire shop wouldn't balance tires he didn't buy there.
"But I bought the lifetime balancing!"
Well, yes, but that was for the tires you bought from us. These are different tires.
"But it's lifetime!"
And someone else joked "good thing you didn't assume they meant your lifetime."
The tire shop meant lifetime of the tires - 40k miles.
The owner assumed lifetime of the vehicle (I guess) - 300k miles.
And the jokester meant the owner's lifetime - 75 years.
As far as vehicle manufacturers, "Lifetime" usually means like 90k-150k miles. It's unsure as these exact definitions are not public knowledge.
But the vehicle manufacturer has no interest in the 200k or 300k mile mark. If the vehicle makes it to 150k, good job. If it goes farther, that's just a happy accident.
Remember, the warranty period is rarely more than 60k miles. That's all they're on the hook for.
Originally Posted by anticubus View Post
Yes-ish. The way I've come to understand the definition of life is "Some amount of time that extends past the last listed service checkpoint in your manual."
That means if you're an average car owner who gets the car at 0 miles, the fluid will not need to be replaced before you replace your car. Average car ownership is just under 6 years, which equates to 90,000 miles given the average 15,000 miles per year driven.
Anecdotally, I've seen transmissions with 300,000 miles on the original fluid. It wasn't babied as a whole, but the drivetrain was not abused (Also had an original clutch that still held tight).
On the other hand, we all probably abuse our cars more than the average person. Track use definitely deserves more frequent fluid replacements just like brake fluid and oil. If you rev it out frequently, there's a lot of motion in the transmission that could degrade the fluid earlier than expected.
Long story short I personally consider any "lifetime fluid" to be a candidate for replacement after 120,000 miles. It's never the right color when it comes out after that long.
Keep in mind 300k city miles vs highway miles. Some vehicles only start up twice per day - start up, shift through gears 1->6 (or whatever), get on highway for 75 miles, never leaving 6th gear, arrive at work. Park.
Repeat on the way home.
A warmed up vehicle cruising steadily at 70mph for hours on end experiences very little stress compared to a city vehicle.
Transmission fluid degradation is almost entirely a function of fluid temperature, which is a function of shifting and high revs.
A low-revving vehicle cruising in the same gear will not heat the trans fluid much.
It's entirely possible a 300k low-stress vehicle might have better looking original fluid than a 35k mile city car.
I have found you can download a small claims form online and when you walk in to the manager to serve them they usually will come to the table. (Writ of Certiorari)
Writ of Certiorari is when the Supreme Court chooses what case it will review next
I think you need to become more familiar with the mechanics of engines and transmissions lol
Just some encouragement
Stomachbuzz is offline   Reply With Quote
The Following 3 Users Say Thank You to Stomachbuzz For This Useful Post:
Opie (12-26-2019), ROFL it's Waffle (12-30-2019), Tcoat (12-24-2019)
Old 12-26-2019, 08:41 AM   #22
p1l0t
p1l0t's Avatar
Yeah you're right it's just Small Claims Writ. Or Notice of Suit depending on the state.
Old 12-26-2019, 09:21 AM   #23
JD001
JD001's Avatar
Drives: Subaru BRZ
What's a 'royal pudding'? Is it something that Epstein and Prince Andrew would partake?
The Following User Says Thank You to JD001 For This Useful Post:
p1l0t (12-26-2019)
Old 12-26-2019, 10:36 AM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
Try a different transmission fluid. Some are too thin and/or slippery and dont allow synchros to work as well.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
p1l0t (12-26-2019), thomasmryan (01-08-2020)
Old 12-26-2019, 12:00 PM   #25
extrashaky
The Following User Says Thank You to extrashaky For This Useful Post:
JD001 (12-26-2019)
Old 12-30-2019, 10:14 PM   #26
ROFL it's Waffle
That's why I'm here I'm learning how important changing the fluid is for heavier driving than daily driving.
Subaru trying to deny my warranty please help! Jordan Silveira BRZ First-Gen (2012+) — General Topics 173 08-02-2016 08:28 PM
Subaru trying to deny my warranty please help! Jordan Silveira Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-30-2016 10:46 PM
Subaru trying to deny my warranty please help! Jordan Silveira Southern California 10 06-30-2016 09:52 PM
Subaru trying to deny my warranty please help! Jordan Silveira Software Tuning 53 06-30-2016 09:50 PM
Subaru trying to deny my warranty please help! Jordan Silveira Scion FR-S / Toyota 86 GT86 General Forum 15 06-29-2016 03:25 AM
