CANADA Canada
Old 09-17-2019, 03:42 PM   #15
Originally Posted by Cookies View Post
Yeah I'm going to have to record some time on the highway as this should be close to the average city mpg of the car. I don't think I could drive it more conservately than I did either and it was 50/50 highway and city. So I still feel like it's off.
Well, its not off, its the actual fuel usage. If it's 50/50 highway you may have something going on with your car given the other history on here. There are a couple of threads covering fuel economy. I think this is about the lowest I've seen for an unmodified car.
Old 09-17-2019, 03:43 PM   #16
Sent from my SM-G955W using Tapatalk
Do you reset the average on your gauge every time you fill up? If you do stop doing that since you need a longer run to get an accurate reading. I reset mine once a month and once it takes at least two weeks of driving to level off at a reasonably accurate average.
Dadhawk (09-17-2019)
Old 09-17-2019, 03:53 PM   #17
I've never reset mine, although I suppose it reset when the battery was swapped out a couple of years ago unless that is held in nonvolatile memory somewhere.
Old 09-17-2019, 03:58 PM   #18
Nah it resets when the power is disconnected. Mine has always leveled out to within .2 but there is very little variation in my driving. I just reset it to see if it will indeed level out in the same range again. It is like a really slow and boring video game.
Old 09-17-2019, 04:00 PM   #19
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I'm with Dadhawk. That mileage sounds low. I get about that with a supercharger and larger injectors, etc..
Old 09-17-2019, 04:22 PM   #20
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I've found that most Ultra 94 pumps I've used will shut off long before full.
I can often, but not always, get $2 -$3 dollars more in after initial stop.
This variance would make a significant difference when calculating mpg.
I'm getting well over 500 kl per tank in mostly Stop & Slow 'rush' hour commuting.
Muskoka800 is offline   Reply With Quote
Old 09-17-2019, 04:26 PM   #21
Cookies
Drives: 2014 FRS Black
I find myself going below 300 in slow commutes fml
Cookies is offline   Reply With Quote
Old 09-17-2019, 04:33 PM   #22
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Topping off is just asking for EVAP system problems. I wouldn't do it.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
Dadhawk (09-17-2019), humfrz (09-17-2019), Jordanwolf (09-17-2019), Tcoat (09-17-2019)
Old 09-17-2019, 08:34 PM   #23
Jordanwolf
Rice King
Jordanwolf's Avatar
Jesus Christ, it bothers me to no end people trying to fill up more because they think it's not full.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
CrowsFeast (09-18-2019)
Old 09-17-2019, 08:41 PM   #24
Cookies
I do, but I also track the mpg through fill ups
Old 09-18-2019, 07:59 AM   #25
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Gotta fill that charcoal canister
/s
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
wparsons (09-23-2019)
Old 09-23-2019, 10:43 AM   #26
wparsons
wparsons's Avatar
You're also filling up with almost 20L left in the tank... it's a 50L tank, if you're filling up and only taking ~30L you're leaving A LOT of range on the table.
I typically get at least 100kms from when it's around 1/4 tank until the light comes on.
flickr
