Old 09-13-2019, 11:34 PM   #15
qqzj
Drives: MDX, Camry
I found this on YouTube. Pretty helpful in showing all the details.
[ame]https://www.youtube.com/watch?v=dhW1GXjPEBI[/ame]
This explains the coverage of the tool.
[ame]https://www.youtube.com/watch?v=llUUjcrfh0A[/ame]
In total we might need three tools. 1. ATEQ Quickset. 2. A TPMS scanner to scan the ID of the old and new sensors. 3. ATEQ VT15 Scan Tool to wake up the sensors so that ECU and sensor can talk and you can scan the ID of the new sensors. The reason for 3 is needed is that the sensors are asleep when car is not moving. Of course, if you can ask a guy at Discount Tire to scan the ID for you, you don't need 2 and 3. Discount Tire's fancy tool can both wake up the sensors and scan their IDs.
qqzj is offline   Reply With Quote
Old 11-08-2020, 12:59 AM   #16
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Hi,
Just wanted to ask whether the ATEQ Qickset X is doing everything that we would need to stop dealer visits. As some of you I also plan to keep stock set and get new wheels/tire/Oem tpms (winter/summer)
https://www.amazon.com/dp/B08GDWF74C...ing=UTF8&psc=1
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 11-10-2020, 11:39 AM   #17
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Originally Posted by Busybee View Post
Hi,
I've never used this tool, but it does appear to do what is necessary. I might recommend you to get the Autel TS series tool instead.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
Busybee (11-26-2020)
Old 11-10-2020, 05:32 PM   #18
ls1ac
ls1ac's Avatar
In short, if you have two sets of TPMS valve stems then ATEQ is the way to go. Keep the first set of working wheels on, read them with the ATEQ, then put the second set on drive to a good shop, have them read the four codes either program them in or give you the codes to enter into the ATEQ.
If you have to buy new sensors, get the programable ones and have the shop clone them to your first set.
The Following User Says Thank You to ls1ac For This Useful Post:
FS: BRZ TPMS sensors P3tras Wheels and Tires 2 05-17-2018 11:36 PM
TPMS Sensors Blucifer Wheels and Tires 0 08-04-2017 03:21 AM
FS: Set of TPMS sensors. GT86Dan Wheels and Tires 12 12-04-2016 08:24 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
