Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 08-16-2012, 06:34 PM   #15
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
What type of installation instructions do these come with?
Spartan65 is offline
Old 08-16-2012, 08:10 PM   #16
Lisa@TrueStreetIndustries
Lisa@TrueStreetIndustries's Avatar
Drives: 13 FR-S, 07 Mustang GT/CS, 95 240sx
Send a message via AIM to Lisa@TrueStreetIndustries
The HID kits are 100% plug and play, so its mostly self-explanatory. However, we will be happy to provide instructions for you with whichever product you order. We can also tell you the easiest/best way to remove anything on your vehicle prior to install to help make this an easy and smooth experience.
Switchback LEDs wont fit through the hole. Too wide by a small bit. Now have to ream the hole
Have you tried sliding these in at an angle? Check your PM!
Lisa@TrueStreetIndustries is offline
Old 08-17-2012, 10:23 AM   #17
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
about the switchbacks...
1. for my FR-S a set with resistors is $26, correct?
2. does setup look lik this? bulb-->resistor-->plug/wire
lbroskee is offline
Old 08-18-2012, 04:48 PM   #18
Jon@TrueStreetIndustries
Drives: 13 Argento FR-S, 06 F-350, 97 240sx
Here is the resistor installation diagram.
Jon@TrueStreetIndustries is offline
Old 08-18-2012, 04:52 PM   #19
pinoyplaya
Drives: WRB MT-BRZ LMTD
Damn thats awesome. It turns yellow/red for the turn signals and brakes and etc?
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline
Old 08-26-2012, 10:09 PM   #20
BigJyoungblood
Enthusiast
BigJyoungblood's Avatar
Drives: 2013 Scion FR-S (37J)
Got the DRL LEDs, great quality, fast shipping, and fantastic to work with thank you Lisa!
BigJyoungblood is offline
Old 08-27-2012, 12:01 AM   #21
WWEVOX
Drives: White Lancer Evolution X
I see that you have a diagram for the rear turn signal LED's but I didn't see any pricing/description. How much are these?
And regarding the resistor; do we need to cut wires for this? The warning seems to warn against mounting the resistor in the harness. Any other options to get normal blinking speed?
WWEVOX is offline
Old 08-27-2012, 07:40 PM   #22
The rear turn signal L.E.D.'s are $12 each. I thought those were in the original post, i guess they got left out somehow. we will update it. Thank you for noticing that.
For the resistor wiring, no wires need to be cut. the resistors come with "splice crimps" for easy reversible installation. The resistor housing has holes for mounting them on the vehicle body. The reason behind the warning of not mounting them on plastic is because they do run warm since power is transferring through them and different thicknesses and types of plastic may melt, so in order to make sure that doesn't happen we recommend not mounting them on plastic.
As far as other options to obtain a "normal" blinking speed, there are replacement flasher relays that we are trying to obtain to supply to you all. More info on those will be available one we have them in hand.
Old 08-28-2012, 07:54 PM   #23
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Sorry for souding like a total newbie but after all the work i put into cars, i have never switched a bulb on one. I wanted to replace the DRL, it seems your LED is like a regular bulb? So when i bolt this in there the DRL will be brighter and white, how about the high beam, or this had nothing to do with the high beam?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline
Old 08-28-2012, 08:17 PM   #24
oso_25
OH HEY NOW!!!!
oso_25's Avatar
Drives: 2013 Scion Fr-s Asphalt
These has nothing to do with the high beams and once you install them they don't funcation with the high beams. Then again why do you need high beams unless you going to get someone's attention
oso_25 is offline
Old 08-28-2012, 08:47 PM   #25
KillaFR-S
Non member
Drives: Red fr-s
Pm sent
Project Baby supra in progress....
KillaFR-S is offline
Old 08-28-2012, 08:59 PM   #26
The DRL is a plug and play replacement. The light from the 9005 LED's is brighter and also a very nice white. Because the DRL also functions as the hi beam, you will only have the LED for hi beams. The alternative to this is replacing the DRL with an HID kit, however that isn't as cost-effective as the 9005's.
All PM's replied!
Old 08-29-2012, 02:01 AM   #27
WWEVOX
Great info. Let us know if you get some relays in. I'd much prefer those over crimp resistors. Then I'll be in for the blinkers front/back and reverse/plate/trunk lights.
WWEVOX is offline
Old 08-30-2012, 02:58 AM   #28
TRD_86
Drives: 2013 86 white
I want the DRL but make sure it at about 6000k color to match my current lowbeam with 6000k hid kit.
TRD_86 is offline
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
Automation Lighting offers LED interior/exterior kits jjdrivesajazz Interior Parts (Incl. Lighting) 393 10-11-2013 10:49 AM
HID PnP Kits engee Cosmetic Modification (Interior/Exterior/Lighting) 25 02-05-2013 04:29 PM
HID_Powerhouse offers HID kits and LED lighting for your FR-S/BRZ KI_ZN6 CANADA 2 07-27-2012 05:13 PM
NA engine kits? Levi Engine, Exhaust, Transmission 36 11-17-2011 11:45 PM
