#15 |
Drives: 15 Impreza
Where in NY are you? Are the battery terminals tight?
#16 |
Drives: brz
so i just tried to disconnect the battery for 30+ min and still nothing
#17 |
Drives: brz
#18 |
Drives: 2013 Scion FRS 6-speed
Try this.
http://www.ft86club.com/forums/showthread.php?p=3219936 Sent from my SM-G892A using Tapatalk |
#19 | |
The car should run fine on stock tune You dont need to reset ecu If the car wont stay running you have left something unplugged, either electrical cable or hose or you have damaged a sensor or wiring. |
#20 | |
Drives: brz
#21 |
Drives: brz
thats what im thinking. ,im gnna get new o2 sensors tomorrow and give that a try and hope it works
#22 | |
Hmmm that might be very expensive. You rearly need to test them first they may be ok. Did you touch intake at all or any intake hoses . The car should run with 02 sensors disconnected, will go into limp mode but should run. You symptoms could be a big intake leak or intake hose disconnected |
#23 | |
Drives: brz
#24 |
Drives: brz
so idk if this matters but i tried to see if the car would run with only one o2 sensor and it does. its the one closest to the overpipe (one with black connector). might mean the other o2 sensor is bad. idk
its able to idle perfectly and go down to normal rpms at around 700 when it gets warmed up. but when i try to give it throttle it starts to die but stays on when i let go of throttle Last edited by Snitko13; 07-21-2019 at 08:06 PM. |
#25 | |
Click link Go to engine hybrid system Engine control Then air fuel ratioo sensor ie front sensor And heater o2 sensor ie rear sensor Test as per instructions These sensors are like $200 each Test before replacing https://demos.starbase7.net/t3Portal..._rm_index.html |
#26 |
Drives: Tornato grey 86
I think you've damage the o2 sensor while changing the exhaust, they can be very sensitive, with a slight knock they can be faulty. but still doesn't explain why the car shuts off right away since you can run fine with only one.
long shot but are all the grounds connected? have you accidentally swapped any plugs, or accidentally have the o2 sensors cables swapped around ? |
#27 |
Drives: brz
so now after the car was running perfectly fine for a couple min with only 1 o2 sensor, it died on its own and now its only cranking
#28 | |
Drives: brz
| BRZ wont start in hot weather! | Coop | Issues | Warranty | Recalls / TSB | 3 | 06-28-2018 05:24 PM |
| INSTALLED TURBO, CAR WONT START | Nightflo | Forced Induction | 23 | 06-23-2018 09:26 PM |
| Car wont start? Anyone else? | ScionFrsFan | Issues | Warranty | Recalls / TSB | 150 | 06-09-2017 09:35 PM |
| car wont start after tune | JesseTheFlash | Software Tuning | 7 | 12-17-2014 12:43 PM |
| Car Wont Start Up HELP !!*** | ScionFR-S | Issues | Warranty | Recalls / TSB | 20 | 11-28-2013 01:01 AM |
