Engine Swaps Discussion of engine swaps. |
07-20-2019, 09:24 AM | #15 |
Drives: Q5 + BRZ + M796
07-20-2019, 10:10 AM | #16 |
Drives: Red BRZ
07-20-2019, 04:04 PM | #17 |
Drives: 2300LB FRS
First video is up!
07-20-2019, 10:49 PM | #18 |
Drives: 2300LB FRS
video is up! |
07-21-2019, 10:38 PM | #19 |
I think this is what you wanted...
[ame]https://www.youtube.com/watch?v=DZOy2VMYbIM[/ame]
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | ShibusaTouge (07-22-2019) |
07-22-2019, 07:37 PM | #20 |
Drives: 2300LB FRS
07-24-2019, 10:05 AM | #21 |
Drives: 2300LB FRS
Why I chose the k24 over the 2JZ or LS!
07-24-2019, 03:29 PM | #22 |
I just Drive.
Drives: in the womb still
Swap out to electric power steering/rack. Some guys use the S2000 system?
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
07-28-2019, 08:59 PM | #23 |
Drives: 2300LB FRS
Engine work has begun! |
07-29-2019, 10:47 AM | #24 | |
The stock power steering is already electric... the motor is just on the column instead of in the rack.
07-29-2019, 10:50 PM | #25 |
That thing is a mess. Should have thrown some degreaser at it before cracking it open.
07-30-2019, 02:30 PM | #26 | |
I just Drive.
Yes, my apologies. Would you get more room swapping to someone else's design??
07-30-2019, 04:54 PM | #27 |
The OEM rack is very compact. The assist motor is mounted to the column right behind the gauge cluster inside the cockpit. They specifically went with this layout to allow them to put the motor as low and far back as possible. Other Subarus do not use this layout.
The Following User Says Thank You to ermax For This Useful Post: | wparsons (07-30-2019) |
07-30-2019, 06:37 PM | #28 | |
If anything you'd probably lose space going to a different rack.
Tags |
honda, k24, racecar, swap, vtec |
Similar Threads | ||||
K24, let's do this. TheVTEC86 | ShibusaTouge | Member's Car Journals | 23 | 08-14-2019 06:56 AM |
