Old 07-24-2019, 11:04 AM   #15
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
New video is up! Goes over why I chose the k24!
ShibusaTouge is offline   Reply With Quote
The Following User Says Thank You to ShibusaTouge For This Useful Post:
MrSkubi (07-25-2019)
Old 07-28-2019, 09:59 PM   #16
ShibusaTouge
Drives: 2300LB FRS
Engine work has begun!
Old 08-10-2019, 08:47 PM   #17
ShibusaTouge
Drives: 2300LB FRS
Another issue:
Power steering won't wire up to the kseriesparts harness, and when I've attempted to take the steering rack motor off, it's sealed on a bearing and won't move.
I'm going to make the rack manual and swap in a manual rack and adapt it to the u-joint towards the firewall
Old 08-12-2019, 05:54 PM   #18
ShibusaTouge
Drives: 2300LB FRS
We got the engine apart!!!
Old 08-13-2019, 03:15 AM   #19
Zer0
Drives: 2015 frs
The rack in the car is already a manual rack. The power steering motor can just be removed from the equation.
Zer0 is offline   Reply With Quote
Old 08-13-2019, 10:29 AM   #20
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
It's been posted by people have raced/driven without the P/S that the manual rack is not setup to be driven manually and is too difficult to steer with.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
ermax (08-14-2019)
Old 08-13-2019, 07:26 PM   #21
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
subscribed.
also what wheel and specs on this pic?
DuMa is offline   Reply With Quote
Old 08-14-2019, 05:54 AM   #22
Zer0
Drives: 2015 frs
Yeah the effort required would be a definite workout. It may be able to be used with a gear device like a quick steer coupler reversed to make more turns lock to lock. It would lighten effort needed at the wheel. Just a thought.
Old 08-14-2019, 07:52 AM   #23
ermax
ermax's Avatar
Yeah I ran with the fuse out once just to see how it was and it is incredibly difficult to drive. I driven plenty of PS cars with belts removed and they are fine once rolling but not the Twins. The ratio is way to high to go without PS.
Old 08-14-2019, 07:56 AM   #24
ermax
ermax's Avatar
K24, let's do this. TheVTEC86
Originally Posted by ShibusaTouge View Post
Another issue:
The motor is really easy to remove. My EPS coupler DIY explains how to remove the column which lets you drop/rotate the motor down so you can access the two bolts that hold it on.
http://www.ft86club.com/forums/showthread.php?t=133606
It will be impossible to drive without EPS though.
