Old 06-20-2019, 11:29 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by 86MLR View Post
All of them, more luck than good drills though.
Damn! I failed to anticipate that answer.
Old 05-24-2020, 08:51 PM   #16
csol
Someone mentioned this functionality can be bypassed with Ecutek tune? Is this correct
csol is offline   Reply With Quote
Old 05-25-2020, 12:46 AM   #17
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Eh to be fair, the 86 (or some trims of the 86 anyway) actually does have a live G meter that is displayable during driving.
Not to take away from what @Ultramaroon said, since clearly it's a safety thing but it's definitely still a feature; just not on BRZ's for some reason. Maybe Subaru is stricter than Toyota when it comes to safety for this kind of stuff.
Which specific models has functional g meter? I'm interested in a retrofit. Need to find the right parts, first then pray it works with the older ECM.
Intent > Content
Old 05-26-2020, 01:14 AM   #18
geraldjust
Drives: MR2, Sliver BRZ
Imposible, its hard coded to the cluster itself independent of ECU or ABS unit. plus it has nothing to do with the ECU.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 05-26-2020, 01:16 AM   #19
geraldjust
any Gt86 cluster. BRZ animation have it disabled and its hard coded to it. gt86 clusters its available.
Older ECM? what do you mean?
Old 05-26-2020, 03:19 PM   #20
solidONE
solidONE's Avatar
2013 A01C calibration computer vs. whatever the +2017 calibrations. Changes in sensor pin locations etc. etc.
Intent > Content
Old 05-28-2020, 03:19 AM   #21
geraldjust
Nope, so that doesnt matter. Im a canbus expert and i know the data on both type of cars are exactly the same coming from ether car. The only difference is that a gt86 cluster is programmed to show live gmeter, vs brz is not. Everything else is exactly the same. Pin changes or anything else doesnt matter. the only thing that matters us the flow of data though the bus and its the same.
Gerald R.
The Following 2 Users Say Thank You to geraldjust For This Useful Post:
mrderp (06-10-2020), solidONE (05-28-2020)
Old 05-28-2020, 05:03 AM   #22
solidONE
solidONE's Avatar
Gerald R.
Noice
Intent > Content
Old 05-28-2020, 08:17 AM   #23
Gerald R.
The question isn't between the two cars but between the pre 17 and post 17 ones.
Old 05-28-2020, 12:37 PM   #24
geraldjust
Yeah thats what i mean in regards of canbus. Same signals used. Their is no difference in the data between a FRS or BRZ or GT86 pre 17 or post 17. The only difference between models (which is small) is between a push button or turn key. But in regards to what the original question asked its not possible to keep on the gauge in any way. not even a ECU or ABS flash nothing. As this is hard coded to the cluster itself.
The Following User Says Thank You to geraldjust For This Useful Post:
Tcoat (05-28-2020)
Old 05-31-2020, 11:33 PM   #25
csol
Do you know if it can be programmed by a 3rd party or how Subaru do software updates for it because there was a recall done in Australia for the tS model gauge cluster software update.
Old 06-01-2020, 03:47 AM   #26
geraldjust
no unless you know programming, reverse engineer the custom chip they use. etc etc... i have dumped both flash info from the cluster but i did not see anything about the g-meter. sorry.
Ultramaroon (06-01-2020)
Old 06-01-2020, 07:47 PM   #27
csol
Yeah it seems Subaru is saying that is how they are having it.
Did you ever try modifying the dumped flash for example changing graphics around if there are any raw bitmap graphics in there?
2017 G meter imprezza BRZ First-Gen (2012+) — General Topics 103 10-27-2020 10:23 PM
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 06:19 PM
TRD Sports Meter Kit imravenit Electronics | Audio | NAV | Infotainment 18 05-10-2013 10:06 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
Does it have MPG meter? 8987846 BRZ First-Gen (2012+) — General Topics 34 05-18-2012 01:35 AM
