| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
Drives: '13 Scion FR-S & '17 Toyota 86
1. Looks like #1 was answered above already! ![]() 2. If you decide to upgrade to 18's, I would recommend that you stick to a square setup. Preferably something lightweight to keep the fun stock feel. Depending on the 18" wheel size and offset that you plan to run, you might need to upgrade to coilovers. Eibach's pro kit will drop you an inch. -Sam |
#16 |
If you mess with any piece of the geometry, you mess with ALL the geometries. Not saying it can't be done, it can, but it's more complicated than just one little adjustment.
Sent from my SM-G975U using Tapatalk |
#17 |
The TRDs give a 1in drop. At 1in you cant pull up over curbs or parking blocks anymore (should be in the habit of not doing that anyways). Driveways require a slight angle unless you go really slow. My wife backed straight out of our driveway the other day and it didn’t touch. I had a very low Integra where the doors wouldn’t clear curbs so I’m already used to all these things. I don’t even pull over curbs in our Suburban.
Long story short, drivability at 1in lower is really no big deal at all. |
| The Following User Says Thank You to ermax For This Useful Post: | maslin (05-09-2019) |
#18 | |
Benz Tech
Drives: 2017 BRZ Premium
The end of my driveway has a little dip that drives my Tacoma's traction control crazy, no scraping or drama from the BRZ. Many years ago a friend opened my 240 door hard over a curb, now I always hop out and open the door for my wife. To be a gentleman of course, not to save the paint
#19 |
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
My tS is lowered 1" on Tein Flex A coilovers. The alignment done is showing an increase of rear negative camber by only .01 degrees. With a kouki model with LED headlights, you'll want to get the adjustable Cusco headlight leveler link, otherwise the car will think the rear is under load and will automatically lower the headlight light pattern cutoff.
#20 |
Drives: BRZ 2018
Effects of lowering by 1 inch:
(1) Ride quality deteriorates noticeably. Unless the road surface is perfect, you spend much of the driving time with your eyes focusing on bump and pot hole avoidance. That actually takes away a lot of the driving pleasure. (2) Shorter life for the shocks, from about 30k miles to no more than 20k miles. (3) More cracking and rattling sooner. The car feels like every bolt has come loose. (4) Need to slow down to a snail pace every time you come to your driveway or speed bump. And you still keep scraping the front end. (5) Much more prone to bottoming out. (6) When driving at night, headlight of other vehicles is blinding your sight, because you are sitting so low. SUV's and trucks are particularly horrible, because their headlight sit high. |
#21 | |||
初級成員
Drives: 2017 86, 2010 Corolla
#22 |
He sees what he wants to see. You cannot stop him from what becomes.
| APR GT250 67 Inch wing w/ 7 Inch risers on SEIBON CSL Style CF Trunk | Tony.86_ | Exterior Parts (Aero, Lighting, Etc.) | 5 | 01-03-2020 11:03 PM |
| 2.5 inch front pipe and over pipe to 3 inch catback opinions (Please give your advice | RedRez86 | Engine, Exhaust, Transmission | 2 | 08-21-2017 02:40 PM |
| Blowout Sale Ambit Wheels 5x100 17 Inch & 18 Inch!! | JonMotoring | Wheels and Tires | 14 | 11-16-2015 07:24 PM |
| ft Perrin exhaust 2.5 inch for 3 inch | FISHBURGLAR | Engine, Exhaust, Bolt-Ons | 1 | 08-03-2015 08:30 PM |
| 17 inch in the front, 18 inch in the back ? | brz_fan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-16-2014 10:35 PM |
