#15 | |
Drives: truck and old car
#16 |
Drives: Firestorm FRS
Sub'd
looking forward to seeing how this comes out. I actually thought about going inverted with my sub also, as its 6 1/2" deep. Its either that or find something shallow enough to fit. |
#17 | |
Drives: 2013 Subaru BRZ Limited in WRB
The Alpine's I have are about 7-7 1/2" deep - they will fit normally in the deepest part of the spare tire well but it would be tight - otherwise I'd have to raise the floor higher than stock. I'm curious how my inverted subs in the corners will sound - they've been in a ported box since day 1 so I'm not expected to be blown away just for the sheer fact it's going to be sealed now.
#18 |
Finished the wooden frames for the fiberglass this morning. Unfortunately it is insanely hot out today and I don't foresee myself actually getting started with a layer of fiberglass today. Ugh - hopefully it cools off soon but the humidity is rough right now.
See the first post for pics of the wooden frames. Also, this car just keeps getting better and better! Both sides of this car are perfectly symmetric! I've never worked on a car where both sides of the trunk were the same - it's always been some computer, fuel fill up, abs lines, or spare tire in the way.
#19 | |
#20 |
I think you'll be okay - it'll be tight but would work right down into the spare tire well. The subs I have are about 7 1/2" deep - you can see in the pic I posted how much higher the floor would need to be.
#21 |
Drives: 2013 Scion FR-S-Asphalt
If you still have your door panels off could you take close up pictures of the bulb socket and bulb of the door still light. Also could you take a close up picture of the harness for the bulb socket at the Tee in the harness. I wanted to know if the wires for the light are tied into the wires at the Tee or if they continue down into the loom. Sorry for thread jacking its just that only BRZ limited cars have that harness. Premium BRZ and FR-S don't have that part of the harness. So Its nice finding a person that has the limited and the door panels off.
Good luck with the build. Thanks |
#22 |
Drives: Argento 6spd FR-S
coming along nicely, is the sub gonna face up or down tho? I keep seeing it both ways so curious.
| The Following User Says Thank You to cruzinbill For This Useful Post: | rmjjensen (08-10-2012) |
#23 |
Self Entitled
Drives: 13' Red FR-S, 12' Toyota Tundra
| The Following User Says Thank You to KRAZYK For This Useful Post: | cruzinbill (08-10-2012) |
#24 |
ah ok, thanks. I may actually be doing a similar design just need time to do it.... i feel like it will be copying tho now. After seein his pics its like he has invaded my brain!!!
#25 | |
| The Following User Says Thank You to rmjjensen For This Useful Post: | Auto-Hauss (08-11-2012) |
#26 |
thanks^^^
#27 | |
Today marks the day when all the fiberglassing is over!! Thank god because it stinks and I forgot just how awful it is to work with that stuff. I finished the boxes with about 6 layers of fiberglass mat and finished the top plate. All that's left to do is T-nuts for the sub screws and mount the L-brackets to ensure the box mounts securely to the car. I'm starting to get super excited! All that's really left to do is mounts for the amps and the false floor. See first post for pics.
#28 |
Subs are mounted - man it sounds incredible! I put a youtube video on the first post (although I'm never sure how much use the farting sounds are).
I'm in a little bit of a predicament though as I have no clue where to put these amps - I didn't think they were that big until I put them in this car ...dam - I'll have to figure something out.
| Max's Audio build | -max- | Electronics | Audio | NAV | Infotainment | 93 | 10-14-2013 09:44 PM |
| Looking for an FRS/BRZ in the SE For Audio | SpeakBeck | Southeast | 8 | 02-17-2013 01:57 PM |
| OEM Audio Plus Subwoofer | K2 | Electronics | Audio | NAV | Infotainment | 28 | 12-21-2012 11:28 AM |
| BRZ Audio Question | poudre | Electronics | Audio | NAV | Infotainment | 4 | 07-11-2012 09:48 AM |
| Audio Options | Aznek | CANADA | 2 | 02-26-2012 04:17 AM |
