Old 05-01-2019, 03:23 PM   #15
chipmunk
Drives: _
Petroleum products are non-polar products, and hence dissolve other non-polar products.
Asphalt erodes because of leaking gasoline or oils, for example. Same logic.
Sent from a potato
chipmunk is offline   Reply With Quote
Old 09-16-2019, 09:54 PM   #16
CEW
Drives: 2015 Subaru BRZ Limited
Hey thanks for the helpful information. I think this bushing could be what’s causing the “brake drag” I’m experiencing on my BRZ. How exactly do you remove the rubber piece? Is it wedged in the caliper bracket?
CEW is offline   Reply With Quote
Old 09-16-2019, 11:14 PM   #17
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@CEW Undo the caliper bolt, spin the caliper out of the way, and pull the caliper pin out. The sleeve will come out with it
EndlessAzure is offline   Reply With Quote
Old 09-17-2019, 12:10 AM   #18
CEW
Ok thanks! Pins were covered in grease so I didn’t realize it was on the pin itself.
Old 05-04-2024, 07:19 PM   #19
redwood9d
redwood9d's Avatar
Thank god i checked this forum before ordering new slide pins, my right rear brake has been making this shuffling noise for months and I finally got around to checking it today
The bottom pin was almost seized and causing my pads to drag, I thought I'd need to order new pins but removing the rubber sleeve freed it up a good bit
Now here's hoping that wasn't the magic piece holding the whole car together O.o
redwood9d is offline   Reply With Quote
Old 05-05-2024, 09:12 PM   #20
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Been using sil glyde for years without issue. Wrong grease can definitely cause issues.
Always get old grease out with brake clean and little brush. Reminds me I'm due this year b
Old 05-28-2024, 06:56 PM   #21
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I ended up getting the grease from toyota. The tube should last me a lifetime and it's not stupid money
autoracer86 is offline   Reply With Quote
Old 05-29-2024, 01:12 AM   #22
Ultramaroon
not playing cards
Ultramaroon's Avatar
For instance, Toyota p/n 08887-01206
autoracer86 (05-30-2024)
Old 06-01-2024, 03:46 PM   #23
Stevedave
Drives: 2013 Scion Frs
Just did front pads and rotors. Bottom pins weren’t seized, but didn’t move very well once cleaned and greased with 3M silicone paste. For science, I picked up new pins and rubber kit (boots, sleeves, whatever) from Advanced Auto. All seems to be good after bedding in new pads and 75ish miles later. I’ll update if the car explodes.
Stevedave is offline   Reply With Quote
caliper guide pin, maintenance, oem brakes, rubber boot, rubber sleeve
Airlift Rear Sleeve Specs NeedsBoostt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-23-2018 03:19 PM
Stuck coilover sleeve. Phothiraj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-05-2017 02:23 PM
WTB: Radio Bezel, OEM Auto Shift knob, OEM hand brake sleeve, OEM stereo Izzy Want-To-Buy Requests 2 05-14-2015 10:01 PM
Shifter bushing sleeve/bolt tolerance supramkivtt2jz Engine, Exhaust, Transmission 1 03-06-2014 12:53 AM
STI rubber lip rubber extension and spoiler rubber extension KSpider Cosmetic Modification (Interior/Exterior/Lighting) 2 10-21-2013 06:48 PM
