#15 |
Huge E85 fan!
Drives: 2016 Scion FRS
oil temp has to go above 100C to boil off water contamination in the crankcase. Condensation happens when the engine cools down and it's a byproduct of compbustion. If the oil can't heat up and boil off the water, it will damage your engine. That's why oil coolers can be dangerous and getting the wrong thermostat is too. Just as bad, is not driving your car and getting it heated up every now and again. Grandmother cars tend to have engines that go to shit at very low mileage, contrary to common wisdom.
So yes, you are not doing your engine any favors and you have to fix it. Go back to the OEM thermostat. If you track the car, get an oil cooler but use one that can be shunted for normal everyday use. |
| The Following User Says Thank You to guybo For This Useful Post: | humfrz (03-31-2019) |
#16 | |
OP will have to edit the fan tables to his tstat which I hope he understands.
| At least it kept me safe! | Mailman1117 | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-13-2016 07:59 PM |
| Be Safe | ButeraFRS | CANADA | 37 | 10-12-2015 09:02 AM |
| SAFE?:running nokya yellow bulbs in factory foglight housing | jbsali | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 07-13-2014 11:42 AM |
| Is this safe? | Anomie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 04-25-2014 10:58 AM |
| Are these safe? | mrlewistan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 03-22-2013 04:22 PM |
