#15 |
Rust bucket enthusiast
Something that hasn't been brought up that I wanted to ask, specifically since you're in the NE like me- were you using 0w-20 oil? Or had you gravitated towards something heavier? I've seen a few oiling issues here in VT from WRX/STI owners who listen to forum posts about needing to use something absurd like 15w-40. The people suggesting it don't mention that they're suggesting its use in 90f temperatures. The fools keep this sludge in their car on -25f days, go screaming on the highway and wonder why they're plagued with oiling problems.
Just asking, since I'm curious. I'm in no way suggesting you're running diesel oil, I really just an asking to know
#16 | |
Feeling like thinking....
Although I've been doing all of my own maintenance for decades on my other vehicles, this one was purchased w/ a "Certified" warranty so I've been having the dealership do every bit of work in the car just to make sure there weren't any warranty questions in case of a catastrophe.. good thing I did! I could go look at my receipts, but I'm pretty certain they always used 0w20. The Blackstone report confirmed that viscosity for the current sample.
Drive like everyone's life around you depends on it...
#17 | |
Thanks, T. Hate to ask this, but would you mind posting a link to your previous descriptions of the problem and/or any changes they made in '14-forward to address it? I searched before even starting this thread, but came up empty. The tech confirmed that I will not be getting the new intake manifold, but has ordered a new short block, heads, cams, etc., along with a TOB and clutch at my request. The service manager could not confirm that the TOB would be the improved updated version, but said that "usually they were very good about staying on top of superceded parts." Is it your belief that the replacement engine I'll be receiving will NOT be susceptible to this issue as my original '13 was? Is there any possibility that the new engine parts they're using are NOS exact versions of my original, prone to the same issue?
#18 | |
| The Following User Says Thank You to ermax For This Useful Post: | why? (03-29-2019) |
#19 | |
Here are some interesting threads about oiling: http://www.ft86club.com/forums/showthread.php?t=63723 http://www.ft86club.com/forums/showthread.php?t=131419 Edit: Forgot to address your question about the new short block. You will not be getting a 2017+ short block. It will be the old spec. I had the same concern as you when I replaced my short block. I was tempted to split the new short block and reapply the packing on my own to be 100% sure it wasn't over done. I decided against that and just crossed my fingers and threw it in. The parts of packing that could block passages to the mains can't be seen externally so it really is just a gamble. I suspect these replacement short blocks were built after the packing issues were addressed though. Last edited by ermax; 03-26-2019 at 11:02 AM. |
| The Following 2 Users Say Thank You to ermax For This Useful Post: | MuseChaser (03-26-2019), why? (03-29-2019) |
#20 | ||
LOL My preaching is spread across probably 20 threads over the last 3 years. Think you probably read it in the recall issue discussion threads. Quick summary. For a period the factory screwed up the application of the sealant. This blocked channels and lead to full or partial oil starvation resulting in spun bearings. The same situation is what has caused the mass failures in the recalled cars. Quote:
Who says the oil pressure is too low at redline? It was the design spec and I am sure they anticipated people driving at redline. There just isn't any data to support that the pressure is an issue beyond people's opinion.
| The Following User Says Thank You to Tcoat For This Useful Post: | MuseChaser (03-26-2019) |
#21 | |
#22 | |
Thanks, Ermax. I read through those threads with great interest... and about 25% comprehension. Most of it is way above my head and skill levels, but the more I read the more I learn.. appreciated. Also, thanks for the edit and response to the short block question. I'm assuming that, since the tech and service manager mentioned all the parts they've ordered (short block, heads, cams, oil pump, etc.), they will be assembling these components and not the factory. Given the situation, I have great confidence that he'll take his time and do the best job possible, but is this cause for concern? Is the fact that the new short block, albeit still a pre 2017+ version, is factory assembled enough to assure less likelihood of further problems? Your post, if I understood it fully, indicates that the oil pressure issues stemmed from packing practices in the short block and not so much from the issues surrounding improper sealant application during the recall or timing cover resealing. A fully-assembled short block SHOULD be a reasonable guarantee of better protection against wear going forward?
#23 | |
Soo.. not to repeat the question I just asked, but... if they're assembling the major replacement components of the engine on site, am I not once again susceptible to the same issues the recall may have caused? Probably worrying too much.. there's probably so much pressure on the tech and the dealership that they'll be as meticulous as possible this time.. and there's no obvious evidence, at least to my eye, that they weren't the first time, either.
#24 | |
Drives: _
Yes it is not a street-legal race car. But it is a street-legal sports car. |
| The Following User Says Thank You to chipmunk For This Useful Post: | ermax (03-26-2019) |
#25 | |
| The Following User Says Thank You to ermax For This Useful Post: | MuseChaser (03-26-2019) |
#26 | |
2022 BRZ Build 2013 FR-S Build |
#27 | |
Element Tuning even added that disclaimer with - "Let me remind you 325 racing slicks and over 1000 lbs of downforce"
#28 | |
| Potential design flaw with factory rear suspension? (WATER in boot area) | WTF | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 243 | 07-26-2018 04:06 PM |
| 2013 BRZ OEM Navigation - flaw or bug in Navi? | PMok | Electronics | Audio | NAV | Infotainment | 7 | 11-22-2013 01:46 AM |
| Major Security Flaw! | DBacon1052 | Issues | Warranty | Recalls / TSB | 69 | 05-04-2013 06:19 PM |
| Fatal FRS Flaw!! | Skin | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-12-2012 05:21 PM |
